part number please
dr_jekyll
hi all .
could anybody find me the part number for the 2 adjuster bolts on the rear suspension.
the ones i need are the ones that controll the camber/toe of the rear wheels , its loicated on the front bar that has a ball joint on the other end. not the adjuster on the upper wishbone
i have a pair that were completely solid si i have had to cut them out :)
Not sure on the part numbers as i've got a list for every nut and bolt on the suspension from when i changed mine, give Steve Manley a call he'll sort you out and doesn't need part numbers :thumbs: theres no adjustment on the rear upper wishbones, the camber and toe are adjusted on lower suspension arm no 1 and lower suspension arm no 2
