LOGIE Posted December 6, 2010 Share Posted December 6, 2010 This is a very odd problem, I have a 1999 RAV4 and when my left indicator is on there is a beeping coming through my left speaker in the boot. It beeps in time with the indicator. Very odd but driving me nuts, please help. Link to comment Share on other sites More sharing options...
mark newman Posted December 6, 2010 Share Posted December 6, 2010 remove your left speaker:p Link to comment Share on other sites More sharing options...
leelbuk Posted December 6, 2010 Share Posted December 6, 2010 I take it that this only happens when the stereo is switched on? Could be a bad earth? Maybe near the light clusters themselves or perhaps dirty contact on relay/a bad relay? Link to comment Share on other sites More sharing options...
Lee P Posted December 6, 2010 Share Posted December 6, 2010 Sound like it has a buzzer for towing electrics, has it got a towbar fitted? Link to comment Share on other sites More sharing options...
LOGIE Posted December 6, 2010 Author Share Posted December 6, 2010 Sound like it has a buzzer for towing electrics, has it got a towbar fitted? Yep its got one fitted, not that id ever use it. Link to comment Share on other sites More sharing options...
Lee P Posted December 6, 2010 Share Posted December 6, 2010 The buzzer is only surpossed to work when the tow bar is in use, by law it has to have a buzzer that sounds when the indicators are on. Just remove the buzzer to shut it up, it will be in the rear quarter panel not too far from the light cluster. Link to comment Share on other sites More sharing options...
LOGIE Posted December 6, 2010 Author Share Posted December 6, 2010 I take it that this only happens when the stereo is switched on? Could be a bad earth? Maybe near the light clusters themselves or perhaps dirty contact on relay/a bad relay? just checked and it happens with the stereo off, but noise is only there when the headlights are off. So to clarify it beeps when i indicate LEFT with headlights/sidelights off, if i switch them on the beep stops. Link to comment Share on other sites More sharing options...
Lee P Posted December 6, 2010 Share Posted December 6, 2010 just checked and it happens with the stereo off, but noise is only there when the headlights are off. So to clarify it beeps when i indicate LEFT with headlights/sidelights off, if i switch them on the beep stops. Ok, will give this one more go. Its the buzzer for the towbar electrics, take out the panel and remove the buzzer as you dont need it. This will stop the noise, it sounds like there is a fault with the buzzer or a bad earth somewhere. Its wired from the tow bar socket to the indicators so you may have to rejoin the wires, all will become clear when you have a look. Hope this helps. Link to comment Share on other sites More sharing options...
LOGIE Posted December 6, 2010 Author Share Posted December 6, 2010 Ok, will give this one more go. Its the buzzer for the towbar electrics, take out the panel and remove the buzzer as you dont need it. This will stop the noise, it sounds like there is a fault with the buzzer or a bad earth somewhere. Its wired from the tow bar socket to the indicators so you may have to rejoin the wires, all will become clear when you have a look. Hope this helps. Thanks Lee much appreciated Link to comment Share on other sites More sharing options...
