neo2810 Posted December 6, 2010 Share Posted December 6, 2010 My case was delivered today so I spent a few hours doing the transplant. First impression was that it huge. Nearly a third bigger than my old case. Love the look though, somewhat like a stormtrooper that's been involved in a fight with a compactor. First of all, this is the mess I was ripping out: http://tapa.tk/mu/519cee9e-3c90-107c.jpg Here's the empty Phantom shell: http://tapa.tk/mu/519cee9e-3d64-0e4d.jpg I started with the PSU: http://tapa.tk/mu/519cee9e-3cd3-fd47.jpg Then fitted the rest of the internals http://tapa.tk/mu/519cee9e-3db9-4351.jpg Finally, tidied all the cabling: http://tapa.tk/mu/519cee9e-3df5-f2dc.jpg The finished product: http://tapa.tk/mu/519cee9e-3e2d-a0ce.jpg Now my old case only had a couple of 80mm fans and one 120mm so cooling was fairly basic. My mobo temp used to be about 43 idle, with CPU at about 40 idle and 55 load and GFX 55-60 idle and 75 load. All at stock. I pushed my Q6600 quad up to 2.7mhz right away and checked my temps: All at idle: Mobo - 28 CPU's - 32-35 GPU - 43 Well happy with those numbers so I'll run it for a few days and then kick it up another 300mhz. This is definitely a cracking case both in terms of layout and ease of install, as well as cooling capacity. It also has custom option to remove fan tray and fit a radiator so water cooling in future should be a simple fit. Link to comment Share on other sites More sharing options...
Josh Posted December 6, 2010 Share Posted December 6, 2010 How is this a rant? That looks great! Link to comment Share on other sites More sharing options...
neo2810 Posted December 6, 2010 Author Share Posted December 6, 2010 How is this a rant? That looks great! Ah, tapatalk forces you to add a prefix, And it's either spoiler, rant or joke. None really appropriate Link to comment Share on other sites More sharing options...
Angarak Posted December 6, 2010 Share Posted December 6, 2010 Whats the noise level like with the case fans? Link to comment Share on other sites More sharing options...
neo2810 Posted December 6, 2010 Author Share Posted December 6, 2010 Whats the noise level like with the case fans? Great. It's near on silent with the fans turned right down (on the handy fan controller built in) and much softer than my old case at full ball. Link to comment Share on other sites More sharing options...
Angarak Posted December 7, 2010 Share Posted December 7, 2010 Nice, Im tempted to switch to liquid cooling for my CPU/GPU. Link to comment Share on other sites More sharing options...
Matt H Posted December 8, 2010 Share Posted December 8, 2010 geekarific. Link to comment Share on other sites More sharing options...
Septic Posted December 8, 2010 Share Posted December 8, 2010 Sorry I'm a bit clueless about these things: why has the new case helped with cooling? It is because its bigger and is more spacious inside? It looks great! Link to comment Share on other sites More sharing options...
neo2810 Posted December 8, 2010 Author Share Posted December 8, 2010 Sorry I'm a bit clueless about these things: why has the new case helped with cooling? It is because its bigger and is more spacious inside? It looks great! It's because I've gone from 2x 80mm and a 120mm fan in a case with no cable management and very tight, to a much bigger case where cables are routed properly leaving clean airflow paths to all the components driven by 3x 120mm, 1x 140mm and 1x 200mm fans. More cooling + better airflow = lower temps Link to comment Share on other sites More sharing options...
Septic Posted December 8, 2010 Share Posted December 8, 2010 It's because I've gone from 2x 80mm and a 120mm fan in a case with no cable management and very tight, to a much bigger case where cables are routed properly leaving clean airflow paths to all the components driven by 3x 120mm, 1x 140mm and 1x 200mm fans. More cooling + better airflow = lower temps Ah thanks for explaining Link to comment Share on other sites More sharing options...
Wez Posted December 8, 2010 Share Posted December 8, 2010 Its always puzzled me with these fancy cases why the PSU that generates lots of heat is mounted at the bottom Fair enough on the cases that have separate compartments. Link to comment Share on other sites More sharing options...
marcAB10 Posted December 8, 2010 Share Posted December 8, 2010 so erm.. is it a flux capacitor or sumfink? Link to comment Share on other sites More sharing options...
Hemanhead Posted December 8, 2010 Share Posted December 8, 2010 Its always puzzled me with these fancy cases why the PSU that generates lots of heat is mounted at the bottom Fair enough on the cases that have separate compartments. I have an NZXT Lexa (Quite an old design) But the PSU is positioned at the top of the case. Link to comment Share on other sites More sharing options...
