Guest alan3579 Posted December 4, 2010 Share Posted December 4, 2010 Hiya, I have a 96, UK spec TT, Fitted with Full decat, Blitz dsbc, induction kit, Iridium plugs, Upgraded smic, and some pipework. I have my dsbc set for around 1.2 bar of boost, and on occasion, usually on a cold morning, the boost can rocket up to 1.25 and I have seen 1.35 on it. So my questions are: 1. Is over 1.2 bar. i.e 1.35 / 1.4 bar to much for stock internals, fuelling and cooling? 2. Does the cold affect the pressure produced by the turbo increase in cold weather? Cheers Quote Link to comment Share on other sites More sharing options...
Nic Posted December 4, 2010 Share Posted December 4, 2010 Cool air = denser air = more oxygen = bigger bang = higher boost. 1.4bar may be okay on the UK turbos, but not sure about the fueling and exhaust gas temps. Personally I'd turn the boost controller down so it is peaking at 1.2bar again to be on the safe side. Quote Link to comment Share on other sites More sharing options...
TonytotheB Posted December 4, 2010 Share Posted December 4, 2010 Can you reduce duty cycle? I am not sure how that boost controller works but as mentioned, lower it just to be safe. Or avoid boosting in early morning conditions before the day has warmed up. Maybe if you can have programmes you can alter to low and high boost, depending on weather conditions. I have the AVCR and can do exactly that Quote Link to comment Share on other sites More sharing options...
Guest alan3579 Posted December 4, 2010 Share Posted December 4, 2010 Can you reduce duty cycle? I am not sure how that boost controller works but as mentioned, lower it just to be safe. Or avoid boosting in early morning conditions before the day has warmed up. Maybe if you can have programmes you can alter to low and high boost, depending on weather conditions. I have the AVCR and can do exactly that I have 4 different settings at the moment, I only use 1, which is for cold and 4 which is for warm. Just wondering if 1.4 bar is gonna do any damage. Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted December 5, 2010 Share Posted December 5, 2010 I have 4 different settings at the moment, I only use 1, which is for cold and 4 which is for warm. Just wondering if 1.4 bar is gonna do any damage. uk turbos are fine up to 1.4 bar mine on occasion using toulene/xylene i have seen as high as 1.7bar to high. but on high setting in the colder weather i often see 1.5 bar in the higher gears 4th 5th Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted December 5, 2010 Share Posted December 5, 2010 im having a similar prob with the cold air and overboost. im getting knock so i think the car is goin to bed until the weather warms up, that and the fact that the wheels just spin Quote Link to comment Share on other sites More sharing options...
Nic Posted December 6, 2010 Share Posted December 6, 2010 uk turbos are fine up to 1.4 bar mine on occasion using toulene/xylene i have seen as high as 1.7bar to high. but on high setting in the colder weather i often see 1.5 bar in the higher gears 4th 5th Is the fueling and the exhaust gas temps okay at those pressures? Quote Link to comment Share on other sites More sharing options...
monsween Posted December 6, 2010 Share Posted December 6, 2010 As mentioned the turbo's "should" be good for 1.4bar but i'd still keep it at 1.2bar. As Nic mentioned check your EGT's and AFR's Quote Link to comment Share on other sites More sharing options...
Guest alan3579 Posted December 6, 2010 Share Posted December 6, 2010 Thanks for the responses Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted December 6, 2010 Share Posted December 6, 2010 Is the fueling and the exhaust gas temps okay at those pressures? i have no idea mate the fcon i thought looks after all this,i have no gauges want to keep stock look inside not hot on the idea of gauges Quote Link to comment Share on other sites More sharing options...
