Gforce GF4a Transmission dog box for sale on SF
SupraHuman
You know it's only a 4 speed box, and you need to make a spacer plate to bring the flywheel in line for the starter, and for correct clutch positioning, plus cut a huge hole in the tunnel and plastic trim? Then fabricate some sort of clutch actuation set up? Then a propshaft is needed. What ratios are in it? And although it seems cheap, it's 1950's technology? I do a fair amount of gearbox swaps, it's never as easy as it may look :(
Bish bash bosh job done, you'll have that done in one afternoon tho Chris, will thy not?? :)
