hodge Posted November 30, 2010 Share Posted November 30, 2010 Hi guys After refreshing my engine which of the above should I go for. Now the pistons, rings, rods and crank went straight back in so nothing to run in really. Just new bearings, gaskets and pumps and 264 cams. Should I error on the side of caution and stick some mineral oil in for a few 100 miles or go straight for the fully synthetic. Thanks John Link to comment Share on other sites More sharing options...
johnny g Posted November 30, 2010 Share Posted November 30, 2010 Give Opie a call and talk him throug what you've done Link to comment Share on other sites More sharing options...
paddynewman Posted November 30, 2010 Share Posted November 30, 2010 I only ever and will ever run semi synth. Even in my GSXR1000's, the semi synth is perfect, Ive never experienced any problems. The Supra has semi, I know being an NA probably doesnt really matter too much regarding that.. but the GSXR is recommended for synthetic...but at £40 to fill it.. and £28 on semi and its definitely run hard.. ive not noticed any issues (one is a k3 and one is a k6 GSXR...neither have had issues) Link to comment Share on other sites More sharing options...
Lee P Posted November 30, 2010 Share Posted November 30, 2010 I only ever and will ever run semi synth. Even in my GSXR1000's, the semi synth is perfect, Ive never experienced any problems. The Supra has semi, I know being an NA probably doesnt really matter too much regarding that.. but the GSXR is recommended for synthetic...but at £40 to fill it.. and £28 on semi and its definitely run hard.. ive not noticed any issues (one is a k3 and one is a k6 GSXR...neither have had issues) John is asking about the mineral oil because he has done an engine rebuild. A mineral oil is mainly used to bed the rings in, if you havent changed them then they should be fine although you should have rehoned it while it was apart. I would still use a mineral oil for the first run up as you only want to run it for a little then change it. I use Millers runnning in oil as it has cleaning agents in it as well and really helps with a new engine. Link to comment Share on other sites More sharing options...
paddynewman Posted November 30, 2010 Share Posted November 30, 2010 John is asking about the mineral oil because he has done an engine rebuild. A mineral oil is mainly used to bed the rings in, if you havent changed them then they should be fine although you should have rehoned it while it was apart. I would still use a mineral oil for the first run up as you only want to run it for a little then change it. I use Millers runnning in oil as it has cleaning agents in it as well and really helps with a new engine. Yea, i was aware, sorry.. i should have stated! Ive only ever rebuilt 2 125cc engines..then I use cheapy mineral for 150 miles, drop it and redo the same again, but given hes just re-using, I just advised the semi route. Link to comment Share on other sites More sharing options...
hodge Posted December 1, 2010 Author Share Posted December 1, 2010 John is asking about the mineral oil because he has done an engine rebuild. A mineral oil is mainly used to bed the rings in, if you havent changed them then they should be fine although you should have rehoned it while it was apart. I would still use a mineral oil for the first run up as you only want to run it for a little then change it. I use Millers runnning in oil as it has cleaning agents in it as well and really helps with a new engine. The bores were perfectly round Lee I took the block into work on night shift and clocked all the bores in, in a few different places, and had no marks or lumps in what so ever so I didn't want to change anything so I left it as was. Ok I'll use some running in oil for the initial start up. Cheers for the help, I appreciate it. Link to comment Share on other sites More sharing options...
ellis Posted December 1, 2010 Share Posted December 1, 2010 Mineral!! Definitely! My UK spec rebuild used synthetic, rushed past the piston rings and shat the fronk crank seal (mechanic error!!) Link to comment Share on other sites More sharing options...
michel lane Posted December 1, 2010 Share Posted December 1, 2010 i just used a cheap fully synth oil 0/30 to flush it through ran it for a bit on idle 1-2 hours. Then replaced it with 10/40 full syn in and ran that for a week and then changed it for 10/50 fully synth for the dyno session and changed it again after. We used to do this with all the cars , had no problems with oil seals or anyother matter. Link to comment Share on other sites More sharing options...
Lee P Posted December 1, 2010 Share Posted December 1, 2010 (edited) i just used a cheap fully synth oil 0/30 to flush it through ran it for a bit on idle 1-2 hours. Then replaced it with 10/40 full syn in and ran that for a week and then changed it for 10/50 fully synth for the dyno session and changed it again after. We used to do this with all the cars , had no problems with oil seals or anyother matter. I assume you mean engines that havent has a rebore, you must always use a mineral oil in an engine that has been bored, been honed, had new rings ect. Edited December 1, 2010 by Lee P (see edit history) Link to comment Share on other sites More sharing options...
