Which suspension
Sharpe
Right well one of the shocks on my Supra has decided it no longer wants to do it job and so I'm thinking now might be a good time to upgrade.
its currently riding high on stock shocks/springs and I want to lower it anyway but would like some advice on what options are available and also recommended setups under £1k
The car itself is a Jspec TT running BPU with around 400bhp.
Thanks an advance.
I would consider BC suspension if your looking for a budget setup. Alternatively, Mr Wilson does a good setup using a revalved stock dampers for around £1200+. Other alternatives would be Tein Super Streets, HSD etc.. Have a look at the traders pages and see what you think.
I have Tein Mono Flex with EDFC. Its a very expensive setup and not really needed for a road car. It is quite firm depending on the damper setting but I prefer it over the stock suspension as I feel the car is more stable.
Edited by mwilkinson (see edit history)
:thumbs: at the CW suspension. Get in contact with Chris, tell him what you want from the car and he'll oblige.
It's expensive (and apparently very good) for budget suspension, but is relatively inexpensive compared to a similar Ohlins, Bilstein, Aragosta or Nitron setup. Side by side, the difference in finish would be very apparent.
Agreed. But one would hope so when your spending £2000+
What I really don't want to do is lower the car very much, as without very expensive further modifications it will kill the handling. My kit is designed to work with a 15 to 20 mm front drop and about a 10 mm rear drop. If you tell me to I'll set it up on its bump stops, but don't shout when handles like a dog :) I have had 2 cars (not Supras...) in here very recently with ultra low mileage, but also ultra *uggered BC dampers on.
