Knocking from rear!
Evil_Nuts
Alright guys....noticed a knocking noise fron the NSR this morning......sounds as if a shocker is knocking. The shocker (Bilstein) has only been on the car 2 months.
Had the vehicle on the ramp and could not find any play in anything....with or without the weight on the thing.....Is it poss the top arms can display no sighns of play but still have a knock?
Also lubed my boot stops....the boot was an absolute arse to open due to being cold...
Cheers
Chris
When is it knocking wheel turning at slow speed, all the time, just over round surfaces etc.
Check all the subframe bolts and suspension arm bolts are torqued to the correct spec.
Check the exhaust is secure and not banging against something.
Overpot holes are so forth, all the subframe etc is tight.....
