WORK EQUIP center caps
shaft
  • 3 weeks later...
I have the same wheels and the same problem :( 2 of mine broke while being refurbed. I spoke To a local wheel specialist and his opinion was that I would be very lucky to find some and even if I did they would be around 50 each, if you can find someone to make new ones I could send you one that isn't broken to use as a template if that helps. Lee
The Work Equip center caps are very poorly made, all mine cracked so i binned them and had some machined out of high a grade aluminium alloy.
You could use st/st if you wished, their pretty easy to make but in small numbers they wouldnt be very cheap.
Hi dunk don't want to be rude but how much did the ones you had made cost??
At the time i was working in a CNC machine shop on machining centers and got one of the turners to knock me 4 up when the boss (my brother lol) was out racing in europe.
We had plenty of material so they just cost me a decent drink.
I would think a good guy on a normal lathe could do them in around and hour or two
