Guest thesmileyone Posted November 25, 2010 Share Posted November 25, 2010 Just a general question really, but what is it on that turbo that gives it the noise it makes ? The big whistle and a noise almost like letting off when you dont have a dumpvalve (fluttering) example : @ 40 seconds. Are there any other turbochargers that are smaller that make the same noise ? Cheers Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted November 25, 2010 Share Posted November 25, 2010 Most single turbo cars have compressor stall, which is the sound you're hearing. The whistle is something the T51R is particularly famous for, but other turbos do make similar noises. Moved this thread to Supra chat as it's not technical. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted November 25, 2010 Share Posted November 25, 2010 The whistle is something the T51R is particularly famous for, but other turbos do make similar noises. Much of it is probably because it's a pretty big turbo HKS do a T62R, which sounds even more mental! Pgg26kxEWk4 Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 25, 2010 Share Posted November 25, 2010 A 900ps rotary?? How long for lol. Think that dyno is a bit poorly... Quote Link to comment Share on other sites More sharing options...
Guest mikethecripple Posted November 26, 2010 Share Posted November 26, 2010 A 900ps rotary?? How long for lol. Think that dyno is a bit poorly... its the anti-surge housing you know how it has holes drilled around the inlet of the turbo?... thats it. it also helps with the turbo spooling up quicker in the low revs hope it helped Quote Link to comment Share on other sites More sharing options...
Guest thesmileyone Posted November 26, 2010 Share Posted November 26, 2010 So do any smaller turbos have an anti surge housing ? Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted November 26, 2010 Share Posted November 26, 2010 My car sounds more like a spaceship when the T51R kicks in with screaner pipes, etc. A truely amazing sound. Quote Link to comment Share on other sites More sharing options...
Nic Posted November 26, 2010 Share Posted November 26, 2010 So do any smaller turbos have an anti surge housing ? Not sure about other brands, but the medium frame Garrett turbos are all available with an anti surge housing, either as standard or as an option. Garrett T04Z Quote Link to comment Share on other sites More sharing options...
Nic Posted November 26, 2010 Share Posted November 26, 2010 The T51R uses a V-band turbo/manifold attachment, which may have something to do with it's distinctive sound. Quote Link to comment Share on other sites More sharing options...
Guest thesmileyone Posted November 27, 2010 Share Posted November 27, 2010 Trying to find any that sound similair and failing...the t04z sounds nothing like it! The reason i ask is when i buy a TT i want to go single asap, but i dont have the £££ to build an engine for a big turbo, 400hp would do me fine! Quote Link to comment Share on other sites More sharing options...
Nic Posted November 27, 2010 Share Posted November 27, 2010 (edited) You can get 400hp quite easily with the stock turbos, if that is your power goal there is no point going single. Running the stock turbos without a BOV will give you a bit of turbo flutter on lift off, it'll be more noticeable with a pod filter. Saying that doing modifications just for the sound is a very strange way of going about things. The smallest single I would go for would be a T61/GT35R which is good for around 550hp, but not a conversion you want to do on a tight budget (£8K-10K+ it'll cost you to do it properly). The GT35R is available with a ported anti surge housing, it is also available with a V-band manifold flange, which may make it sound a little like a T51R. You could buy the HKS T51R Kit with out the turbo and then bolt on a Garrett GT35R or GTX35R turbo. The T04Z is good for 600+hp. Edited November 27, 2010 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
bignum Posted November 27, 2010 Share Posted November 27, 2010 I think he wants the single sound:) i know someone else who is doing it only for the sound:innocent: Quote Link to comment Share on other sites More sharing options...
Guest thesmileyone Posted November 28, 2010 Share Posted November 28, 2010 Yeah its more the sound, im not in any rush to get to big power, if i waste money getting there by trying different setups then so be it, its only money after all! TBH i would rather spend it on cams, head, block etc than buying a massive turbo straight away Quote Link to comment Share on other sites More sharing options...
Stephendjb Posted November 28, 2010 Share Posted November 28, 2010 If your just doing it for the sound just get one of these http://cgi.ebay.co.uk/TURBO-Whistle-Sound-Noise-BMW-3-1-Series-Z4-M3-Z3-/290473490070?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43a191b696 Quote Link to comment Share on other sites More sharing options...
Guest thesmileyone Posted November 28, 2010 Share Posted November 28, 2010 lol Quote Link to comment Share on other sites More sharing options...
