MKIV: HKS VPC/CGG plug'n'play
Klaus
HKS VPC unit, HKS GCC unit, HKS Pressure and Temp Sensors, HKS sensor harness, HKS plog'n'play harness, VPC chip after your choice (standard injectors, 680-750cc or 1000cc). 100% working order, 100% cosmetic order.
Will replace the restrictive MAF sensor and enable you to tune the correct AFR through the rpm's. Will suport up to 700hp without problems.
Euro 1000,- including shipping within Europe.
NB: Will not split the kit.
Thanks, Klaus
  • 11 months later...
