w41k3r Posted November 24, 2010 Share Posted November 24, 2010 hey, after my car breaking down after the tunnel run we finally took the diff of today to see if it was that that had gone there were a few pieces of metal floating few teeth missing bits but nothing major to stop drive the car would not drive but could be pushed, diff off now and right wheel spins freely left wheel moves backwards but forwards is stiff and feels like it gets stuck part way car goes in gear fine, idles fine, still feels like it has a clutch no previous slipping of any sort just puzzled as to whats left to check any ideas does the car have handbrake shoes ? but as said dont think this would stop drive as we can push it what should we check for???? also when it went it felt like a pull from the rear then an almost sketchy handling feeling like a wheel locked up but also revs shot up and no drive Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 24, 2010 Share Posted November 24, 2010 You can't possibly seriously expect a diff with bits missing off the teeth to necessarily drive either correctly or even at all? If the diff is an open one you may find the sun gears have broken, that would stop all drive. Have you got any decent photos of it out of the casing, if so I may be able to tell you from those if it's just a diff problem. Sounds terminal to me though, given the price and availability of diff parts for these from Toyota. Is the crown wheel and pinion OK? If so you MAY be able to fit a TRD LSD centre section to repair it. Quote Link to comment Share on other sites More sharing options...
w41k3r Posted November 24, 2010 Author Share Posted November 24, 2010 It was an open diff and the bits missing were mm`s i have a whole new lsd to fit in its place going on tomoz its also the wheel not spining freely thats a prob backwards freely but not forwards ???? Quote Link to comment Share on other sites More sharing options...
Ian C Posted November 24, 2010 Share Posted November 24, 2010 Remove obviously broken diff, fit the new diff, recheck everything afterwards. I imagine your problems will clear up Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 24, 2010 Share Posted November 24, 2010 Yes, sounds like the cheapest and easiest way forward, hope it works out for you, good luck! Quote Link to comment Share on other sites More sharing options...
w41k3r Posted November 25, 2010 Author Share Posted November 25, 2010 cheers chris will fit later as its a quick job this is my third i will also get vids of whats happening does anybody have an idea why the pass rear is having so much trouble spining bar the obvious caliper this is what happens spins almost round gets tight spins a little freer gets tight spins a little freer gets stuck like a warped disk maybe if that helps what could cause the problem like things to check does the handbrake use the caliper or shoes ?? i read a thread where some one said there car lost drive and it was down to a cv joint could this be a possibility ?? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 25, 2010 Share Posted November 25, 2010 Just take the disc off and it will immediately remove the possibilities of a warped disc, seized caliper or binding hand brake shoes from the equation Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted November 25, 2010 Share Posted November 25, 2010 cheers chris will fit later as its a quick job this is my third Not trying to sound condescending but........ Is it possible you might still be on your second if you had taken your time installing it? There is quite a bit of jiggery-pokery* to getting a diff set up for reliability. *(Yes, that IS the official recognised term for it!) Quote Link to comment Share on other sites More sharing options...
w41k3r Posted November 25, 2010 Author Share Posted November 25, 2010 they were just open diffs that took a thrashing my bros a mechanic so i have faith in his installing, i smahed the 1st one up 2nd few teeth missing and now finally a proper diffs going on Quote Link to comment Share on other sites More sharing options...
w41k3r Posted November 26, 2010 Author Share Posted November 26, 2010 UPDATE put the diff on yesterday and left it for the night, today went out started the car after a flat battery put it in gear clutch out and nothing still no move = jacked the car up 1 side turned the rear wheel manually propshaft spins (car not running) = same but with car running put in gear let clutch out propshaft has no movement alot of oil under the passenger side of the car cant visually see any cracks or holes in the box what am i too check next any ideas ?????? Quote Link to comment Share on other sites More sharing options...
Nic Posted November 26, 2010 Share Posted November 26, 2010 what am i too check next any ideas ?????? Are you still testing it with the broken internals? If there are teeth missing and debris inside, the seals and bearings are probably also FUBAR. As has already been said, replacing the diff, bearings and seals should solve the problem. Quote Link to comment Share on other sites More sharing options...
w41k3r Posted November 26, 2010 Author Share Posted November 26, 2010 as said in previous posts i have replaced the broken diff with a NEW lsd/torsen diff and we still have a prob so rules out diff Quote Link to comment Share on other sites More sharing options...
Nic Posted November 26, 2010 Share Posted November 26, 2010 as said in previous posts i have replaced the broken diff with a NEW lsd/torsen diff and we still have a prob so rules out diff Did you also replace the bearings and seals? If debris has got into the bearings, it could be a seized bearing causing your problems. Was the final drive gearing in good condition or replaced? Quote Link to comment Share on other sites More sharing options...
w41k3r Posted November 26, 2010 Author Share Posted November 26, 2010 its a whole new diff unit on now bought from keron the a01b i think they were what bearings and seals do you mean i presume you ment the old diff unit???? Quote Link to comment Share on other sites More sharing options...
Nic Posted November 26, 2010 Share Posted November 26, 2010 its a whole new diff unit on now bought from keron the a01b i think they were what bearings and seals do you mean i presume you ment the old diff unit???? So you bought a whole new diff casing and diff assembly? See work shop manual HERE Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 26, 2010 Share Posted November 26, 2010 If the clutch is up and the propshaft isn't turning with it in gear, it's either the gearbox or the clutch. Quote Link to comment Share on other sites More sharing options...
