What's "worse" a NA with a 3" exhaust or a TT with a 2.5" one ?
alex2jz
Chaps i need your advice. I'm planning to get an aftermaket exhaust. I will most likely go NA-TT next year (finally decided :p) but until then i need a change.
My question is what exhaust to get 3" or 2.5" ? I will still be using my car with the NA engine more than an year now, MOT is coming... What's the best compromise ? I just want to get one exhaust which i can use with bot engines.
Will the NA engine with a 3" exhaust have backpressure issues ? will it be obnoxiously loud (both cats in) ? What are the consequences of a TT engine with a 2.5" exhaust fitted ? I want to know :)
Cheers
Alex
an NA is stupidly loud. i had a blitz nur spec R on my tt and single and it wasnt as loud as my mates NA (same exhaust). i didnt like being a passenger in the NA, the noise honestly does your head in.
Cheers mate. Was your friends NA decated ?
You won't lose any power fitting a TT exhaust, it will be loud though (especially if it is decatted as well) as they usually have just a single silencer, aftermarket NA exhausts tends to have an additional silencer on the mid pipe.
Kind of depends what sort of power you're going for once N/ATT? if you're not going much over 360-380 then you can get away with a 2.5" remember that the std TT is 2.5", i also suspect that the N/A will suffer with a 3" system, and its nothing to do with back pressure, its about reversion, a larger bore will change the characteristic's.
I run a tanabe touring which is a 3" cat back with no issues with mine :shrug:
Did you dyno it before and after, i would be surprised if you haven't lost a bit of mid range torque.
To be fair i didnt realy try out the stock exhaust anyway so i dunno whether there is much difference.
Of all the NA's ive drove with 2.5s catbacks dont feel as quick but that maybe just me. Bare in mind i have 2 silencers in line and all pipework prior to the catback is 2.5".
Im eventualy going to get it down to ryan for a going over like daryll did.
Doubt that, the guy can torque for england:p
Yarp yarp yarp :D
id agree with that i have a 3 inch TT exhaust on my NA (not sure what brand as it came with the car) and its far to loud for day to day use in my opinion :) will be changing it soon :)
