eBay Clear Side Repeaters
SamuraiFlash
To remove, you pretty much push the sidelight horizontally and pull gently forwards at the same time.
It has a clip one side and a metal springy clip the other. Depending on which way around the sidelight has been clipped in prior to this is as to which side the springy metal clip is (this is the side that will clip out)
Hope that makes sense.
As Scott said, when you see your new ones, it will help you understand how to remove them :) :thumbs:
Yes they should fit. The old ones just pop out. When your new ones arrive your have a better idea on how they clip in.
b;2965575']To remove, you pretty much push the sidelight horizontally and pull gently forwards at the same time.
Thanks for your help guys, this makes sense and sounds like it should be straight forward even for someone like me :)
Thank you.
personally i would get genuine toyota ones....about 20-25 the pair iirc...off the new corolla, mr2, celica or avensis....they dont yellow!
Cheers Keron, I'll buy a set of these instead, i'd rather do it once :)
