Guest WRC Posted June 16, 2005 Share Posted June 16, 2005 have just fitted a bosst gauge, and put my tt in the parallel operasion. it boost around 1.1-1.2 in 2nd gear 1.3 in 3nd 1.4 in 4nd,5nd, havent tried 6nd gear. this is to much to my jspec turboes. how will i lower the boost?? the car has mines ecu, decat, open airfilter. Quote Link to comment Share on other sites More sharing options...
imi Posted June 16, 2005 Share Posted June 16, 2005 u need a restrictor ring Quote Link to comment Share on other sites More sharing options...
Guest WRC Posted June 16, 2005 Share Posted June 16, 2005 ok, but i dont have any, where shall that be, and how does it look?? isnt there any adjustments that can be done on the turboes/actuators?? Quote Link to comment Share on other sites More sharing options...
terribleturner Posted June 16, 2005 Share Posted June 16, 2005 No, as Imi says your best off getting a restrictor Ring off of Chris Wilson who can be found floating around the forums here. Quote Link to comment Share on other sites More sharing options...
CJ Posted June 16, 2005 Share Posted June 16, 2005 When my car was a "normal" TT, I used a restrictor ring and upped the boost via a BC. Unfortunately, when I run in parallel mode, they still over boosted to 1.5 bar. I tried everything inclduing turning the BC off but it still happened and despite several posts on the board, no one could explian why. Quote Link to comment Share on other sites More sharing options...
terribleturner Posted June 16, 2005 Share Posted June 16, 2005 CJ, would it be possible to get Chris to make one up, say with a much smaller hole and then use the BC. but then i guess you'd make the EGT rise more. Quote Link to comment Share on other sites More sharing options...
CJ Posted June 16, 2005 Share Posted June 16, 2005 CJ, would it be possible to get Chris to make one up, say with a much smaller hole and then use the BC. but then i guess you'd make the EGT rise more. Possibly. I used a CW ring set at 1.2 bar (IIRC) but it still didnt hold to that level of boost. Strange thing was, it did in sequential mode but not parallel. Quote Link to comment Share on other sites More sharing options...
Guest WRC Posted June 16, 2005 Share Posted June 16, 2005 so a restrictor ring is a ring with a smaller hole, that you put in your exhaust?? anybody have a picture with sizes on or something?? Quote Link to comment Share on other sites More sharing options...
GeordieSteve Posted June 16, 2005 Share Posted June 16, 2005 Nope but Miami GT do em for £25 http://miami-gt.com/product_info.php/cPath/100_7/products_id/332?osCsid=b999aba814cb56cbf8066ec005f19b6a Quote Link to comment Share on other sites More sharing options...
Steve Posted June 17, 2005 Share Posted June 17, 2005 CJ, would it be possible to get Chris to make one up, say with a much smaller hole and then use the BC. but then i guess you'd make the EGT rise more. I asked Chris this question when getting mine done. Basically he said no, as it would cause high EGTs like you say. Quote Link to comment Share on other sites More sharing options...
Guest WRC Posted June 21, 2005 Share Posted June 21, 2005 the car was in parallel mode when i postet this. have now set the turboes back to standard. but have still problems with the boost. i have a restrictor ring that should hold it to 1.1bar. but it boost up to 1.2 in second gear.in 3nd gear it is not stabil, sometimes it boost 1.25 but sometimes it goes up to 1.4bar.could it be a leak somewhere? the car got a Mines ecu, hks sparks,apexi airfilter, decat and big exhaust. Quote Link to comment Share on other sites More sharing options...
