Clutch Fluid top up
supRo
I'm gonna sound stupid but hear it goes!...
I have a manual TT
Is the reservoir inbetween the brake reservoir and engine for the clutch? :stupid:
The recommended fluid is Dot 3...not sure whats in there, is it ok to top up with Dot 5.1?
:rolleyes:
Cheers
Guest slow dog
drain it and put some 5.1 in it will take longer to boil than dot 3 and yes you have the right place mate
Guest slow dog
should not really mix it mate just drop it all out and bleed the new stuff in or bring it by the workshop and i will show you how to do it you can use my tools if you want no charge :D
Isn't Dot 5.1 an evolution of Dot 4.0 and isn't Dot 4.0 an evolution Dot 3.0 and therefore they are compatible and can be mixed?
Saying that, it still would be nice to drain the old fluid out and put some new stuff in. :)
Guest slow dog
yep if you gonna do a job do it proper drain the lot flush it with some new stuff then top it up bleed it job done
