uk clock
hp006
Aw man how can a uk spec work without one. I used mine all the time. I remember getting into it after a night shift clicking on the heated seats and seeing it was -5 outside. Once the car was heated up it seemed extra warm knowing it was freezing outside.
Shame they cant be fitted to a jspecs.
Might have to try MR T for the part.
Im not entirely sure it works, however i was led to believe that its a sensor that is just behind the front bumper. I know uk clock has 6 pins japspec has 4. Think the 2 extra pins are for the sensor. I have uk nirrors now but dont think there any sensors in there??
Anyone else shed some light??
Thought it was a case of adding the sensor then wiring to the clock??
Some one also mentioned the sensor maybe linked to the a/c pump??
Trying to get my car as near to uk spec as possible and think the clock is the last part -abs which im not worried about
Yeah that sounds OK. I thought you were expecting to put the clock in and that would be that :D
If you add the clock and wire in the sensor I can't see any reason why it wouldn't work :)
