mplavery Posted January 9, 2011 Author Share Posted January 9, 2011 (edited) More updates Im a bit further now since the weather not been to bad, Inlet manifold is off inc the cam covers and turbo pipes....... MAN how many vacuum hoses do these bloody cars have ! lol So now i have been cleaning up the turbo pipes, respraying them to make them look OEM new and i am sending the mainifold and cam covers and a intercooler pipe away to get chromed. I have orderd my Black hoses too as i have gone off the blue ones Here some pics so far Dirty pipes Pipes all cleaned and sprayed Just a quick Qst Im going to take the water outlet which goes on the top rad hose and i can see the bolts where it goes onto the head but i noticed this How is that connected, Looks like a hose but no clips holding it on, thought i would ask before i jump in and take it off Oh some more goodies Edited January 9, 2011 by mplavery (see edit history) Link to comment Share on other sites More sharing options...
leelbuk Posted January 9, 2011 Share Posted January 9, 2011 Smooth spark plug cover that Where'd you pick one of them up from? Link to comment Share on other sites More sharing options...
jackso11 Posted January 9, 2011 Share Posted January 9, 2011 its just pushed on, just undo the 2 long bolts holding it to the engine and it will pull off (upwards). there is a rubber washer seated in a groove around the pipe it it pushed down on to so might be tight. I put the round end of a spanner against the bottom of it and tapped the spanner up with a hammer to knock it up and off......if that makes sense. Link to comment Share on other sites More sharing options...
j_jza80 Posted January 9, 2011 Share Posted January 9, 2011 More updates Pipes all cleaned and sprayed They look fantastic Link to comment Share on other sites More sharing options...
supradibbs Posted January 9, 2011 Share Posted January 9, 2011 When you install the water pipe use a new o ring with plenty of silicone grease i.e vasalene can be a pig to reseal as the o ring tends to roll. looks great so far please dont install the bling rad cover the black looks super sexy Link to comment Share on other sites More sharing options...
mplavery Posted January 9, 2011 Author Share Posted January 9, 2011 Smooth spark plug cover that Where'd you pick one of them up from? Thanks mate but its just a carbon one from Whifbitz, looking forward to fitting that lol Link to comment Share on other sites More sharing options...
mplavery Posted January 9, 2011 Author Share Posted January 9, 2011 its just pushed on, just undo the 2 long bolts holding it to the engine and it will pull off (upwards). there is a rubber washer seated in a groove around the pipe it it pushed down on to so might be tight. I put the round end of a spanner against the bottom of it and tapped the spanner up with a hammer to knock it up and off......if that makes sense. When you install the water pipe use a new o ring with plenty of silicone grease i.e vasalene can be a pig to reseal as the o ring tends to roll. looks great so far please dont install the bling rad cover the black looks super sexy Ahhhhh cheers guys, i kinda guessed it was a push on fit but i have never seen anything like that before so i thought i would ask the Qst Will do that Supradibbs, thanks for the tip. You know what, i have painted the Org fan couling black as i wanted i nice clean finish but then i saw this going cheap and could not make up my mind up if it would look good or not, so i have bought it to see how it looks and if it looks crap i will sell it again Link to comment Share on other sites More sharing options...
mplavery Posted January 9, 2011 Author Share Posted January 9, 2011 They look fantastic Im very pleased with how it looks, did not want to go chrome, just a nice clean look and its come out great ! Link to comment Share on other sites More sharing options...
sdistc Posted January 10, 2011 Share Posted January 10, 2011 The turbo pipes look very neat and clean... good job! Might I advise a spray job on the fan blades as well - the fan gets yellow as it ages, and looks quite revolting. Link to comment Share on other sites More sharing options...
mplavery Posted January 10, 2011 Author Share Posted January 10, 2011 The turbo pipes look very neat and clean... good job! Might I advise a spray job on the fan blades as well - the fan gets yellow as it ages, and looks quite revolting. The fan blades are filthy, i tried a little brakecleaner which cleaned them up well so im going to do that Link to comment Share on other sites More sharing options...
Matt H Posted January 10, 2011 Share Posted January 10, 2011 Looking really good. What did you 'spray' the pipes with in the pics from post #26? Link to comment Share on other sites More sharing options...
jackso11 Posted January 10, 2011 Share Posted January 10, 2011 Or, take the fan blades off and get some hydrogen peroxide in a tub, sink the fan in it and leave it in the sun (cover the top of the tub in clingfilm to seal it) or under a UV light. That will take the grime off and have it looking like new. Link to comment Share on other sites More sharing options...
mplavery Posted January 10, 2011 Author Share Posted January 10, 2011 Looking really good. What did you 'spray' the pipes with in the pics from post #26? A friend of mine told me about a website called Frost http://www.frost.co.uk/ and do lots of stuff for Restoration etc. The paint i used was to make your parts look OEM new again and of course its heat proof..Its the same paint they use when they refurbish Alternators/water pumps etc Good stuff and really came out well Link to comment Share on other sites More sharing options...
Westy Posted January 10, 2011 Share Posted January 10, 2011 Did you get the silver paint from that website mate!? I'm guessing from the finish that it was an aerosol...a link would be good. Link to comment Share on other sites More sharing options...
Westy Posted January 10, 2011 Share Posted January 10, 2011 Ohh...and car is looking very nice!!!!!!!! Link to comment Share on other sites More sharing options...
Matt H Posted January 10, 2011 Share Posted January 10, 2011 A friend of mine told me about a website called Frost http://www.frost.co.uk/ and do lots of stuff for Restoration etc. The paint i used was to make your parts look OEM new again and of course its heat proof..Its the same paint they use when they refurbish Alternators/water pumps etc Good stuff and really came out well Yeah, defo came out well. Really well cheers for the link. Link to comment Share on other sites More sharing options...
mplavery Posted January 10, 2011 Author Share Posted January 10, 2011 Did you get the silver paint from that website mate!? I'm guessing from the finish that it was an aerosol...a link would be good. I got the paint from FROST mate, Aluma Blast, there are a few types of shades to choose from http://www.frost.co.uk/item_Detail.asp?productID=9572&frostProductName=Aluma Blast (340g) Aerosol Link to comment Share on other sites More sharing options...
Westy Posted January 10, 2011 Share Posted January 10, 2011 Cheers. Link to comment Share on other sites More sharing options...
mplavery Posted January 11, 2011 Author Share Posted January 11, 2011 A few more pipes done, came out very well and cant wait to see them on the car, I also sprayed the breather pipes black agaon for that more cleaner look I started to put some metal polish on to the heat shroud and is coming out nice and shiny so i will do the exhaust heat shield too This is half polished Link to comment Share on other sites More sharing options...
Lude Posted January 13, 2011 Share Posted January 13, 2011 looks fab mate, what paint did you use for the turbo pipies? in regards to the hardpipes that the vacuum's go to, im thinking of replacing them with silicone, then maybe routing them underneath the turbo pipes out of sight? Link to comment Share on other sites More sharing options...
wallis Posted January 13, 2011 Share Posted January 13, 2011 Looking very good mate, should look awesome like it just came out the factory ! Great work fella :-) Link to comment Share on other sites More sharing options...
jackso11 Posted January 13, 2011 Share Posted January 13, 2011 how long did it take to take the turbo and breather pipes off? Link to comment Share on other sites More sharing options...
pistonbroke Posted January 13, 2011 Share Posted January 13, 2011 Gonna look lovely no doubt, but the cam cover would have to have been black with yellow viper stripes In fact, Mr Mitchell is pretty good at viper striping cam covers, he could stripe the carbon one just to make it that little bit more 'one off' Link to comment Share on other sites More sharing options...
Lude Posted January 14, 2011 Share Posted January 14, 2011 how long did it take to take the turbo and breather pipes off? +1 Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 14, 2011 Share Posted January 14, 2011 (edited) Gonna look lovely no doubt, but the cam cover would have to have been black with yellow viper stripes In fact, Mr Mitchell is pretty good at viper striping cam covers, he could stripe the carbon one just to make it that little bit more 'one off' i was going to say the same thing, would look mental showing the carbon off. turbo pipes and everything you can take off in a good hour... but i have had alot of practice/jobs in. Edited January 14, 2011 by Rob_Mitchell (see edit history) Link to comment Share on other sites More sharing options...
