redsupraman82 Posted November 21, 2010 Share Posted November 21, 2010 Guys, im looking to convert my areotop to a manual, how hard is this to do myself?? im not bad with a spanner and have a lot of patience and logical thinking towards mechanics. has anyone every done a guide on here about this?? im looking at getting just the 5 spd W58 box obviusly with the other bits to do the conversion, but any tips or things i should look out for etc???? Quote Link to comment Share on other sites More sharing options...
monsween Posted November 21, 2010 Share Posted November 21, 2010 I think you need to get the trans tunnel welding in aswell as changing the box over, could be wrong tho Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted November 21, 2010 Author Share Posted November 21, 2010 so there is some welding involved?? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 21, 2010 Share Posted November 21, 2010 There is welding for the 6 speed but not for the W58, theres a complete conversion for sale on here at the mo. Its fairly tricky, you need to cut a hole in the bulkhead, install a clutch cylinder and hydraulic lines, piss about with wiring, remove/modify pedals so not for the novice really. Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted November 21, 2010 Author Share Posted November 21, 2010 ah i see! i do really want to give this ago as i want to learn. i will have a friend helping me who is a mechanic but not that clued up on jap cars! so was there no one that did a thread about there conversion and how they did it? Quote Link to comment Share on other sites More sharing options...
Lude Posted November 21, 2010 Share Posted November 21, 2010 patience is a virtue! i have done an auto to manual conversion, on my Fairlady Z tho, pedal was potchy, pain int the arse bleeding the clutch etc, if you take your time on it and dont rush itl pay off Quote Link to comment Share on other sites More sharing options...
TLicense Posted November 21, 2010 Share Posted November 21, 2010 There is welding for the 6 speed but not for the W58, theres a complete conversion for sale on here at the mo. Its fairly tricky, you need to cut a hole in the bulkhead, install a clutch cylinder and hydraulic lines, piss about with wiring, remove/modify pedals so not for the novice really. By cutting a hole in the bulkhead, if you mean for the clutch pedal, it's already there so no cutting required. The only cutting required is for the replacement of the transmission tunnel. Quote Link to comment Share on other sites More sharing options...
Homer Posted November 21, 2010 Share Posted November 21, 2010 Just to add - it's not necessary to weld in a new trans plate (though would be good if you have the tools). It's enough to bolt and bond it in place. I don't think the stock plate is welded in from the factory either. One other thing that's often missed on these threads is a support bracket for the clutch slave line needs to be made under the car, this is welded in on the factory cars, bur could be safely done by a bolt. Provided you have some good jacks and ideally a geabox jack it should be a reasonable job for a competent DIYer. The only thing you may need a professional to do is allign the prop shaft mounting shims Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 21, 2010 Share Posted November 21, 2010 By cutting a hole in the bulkhead, if you mean for the clutch pedal, it's already there so no cutting required. The only cutting required is for the replacement of the transmission tunnel. Really? So auto cars come with the hole? I assumed, incorrectly, it would be uncut. Is there a bung fitted then? Quote Link to comment Share on other sites More sharing options...
dude Posted November 21, 2010 Share Posted November 21, 2010 Really? So auto cars come with the hole? I assumed, incorrectly, it would be uncut. Is there a bung fitted then? Gromet dude!!! No Wallace though! Quote Link to comment Share on other sites More sharing options...
Homer Posted November 21, 2010 Share Posted November 21, 2010 Really? So auto cars come with the hole? I assumed, incorrectly, it would be uncut. Is there a bung fitted then? I needed to drill out the two holes for the clutch master mounting bolts to go through on my '94 car, the centre where the arm goes through only had a gromet as Tony mentions. It easy though as the two drill holes are already stamped into the bulkhead sheet metal. Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted November 25, 2010 Author Share Posted November 25, 2010 cool thanks for your help guys. i will need as much help as possible with this onw, as im not even sure what to remove first!! lol....................oh dear! Quote Link to comment Share on other sites More sharing options...
dude Posted November 25, 2010 Share Posted November 25, 2010 cool thanks for your help guys. i will need as much help as possible with this onw, as im not even sure what to remove first!! lol....................oh dear! If you get stuck call AFR and i'll talk you thru it. Quote Link to comment Share on other sites More sharing options...
monsween Posted November 25, 2010 Share Posted November 25, 2010 If you get stuck call AFR and i'll talk you thru it. Cant grumble at that, GREAT service there dude Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 25, 2010 Share Posted November 25, 2010 Im gonna be doing that myself! Quote Link to comment Share on other sites More sharing options...
redsupraman82 Posted November 25, 2010 Author Share Posted November 25, 2010 Thanks guys I will I would just give it to someone to do for me but like I said I want to learn it's not just cutting the cost of getting someone to fit it, I just want the sense of achievement doing it myself if that makes sense?? Quote Link to comment Share on other sites More sharing options...
