Mike17 Posted November 20, 2010 Share Posted November 20, 2010 Hello! I have a very loud banging noise coming from somewhere on the back of the car. It started only as the car went round a corner to the right but is now starting to do it going straight as well, however not constant! You can feel in when it does it on the floor of the car as I'm sat in it but doesn't affect the steering at all. We have put it on a ramp and checked all four tyres and wheel bearings, the nsr has a tiny (and I mean millimetres) bit of play in it so we can change that but is that was is causing the loud banging?! It is not the exhaust which was solid as a rock... I've been told it could be cv joints?! Is this likely?! I have no idea what these are so any info would be awesome!! The car has 140km on the clock and is used every day so by no means a 'show' car! It has been off the road for a year having bodywork done so wandering if something has seized up while it's been sat for a year Has anyone come across this before? Any suggestions very gratefully received!! Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted November 20, 2010 Share Posted November 20, 2010 Checked your wheel nuts? Quote Link to comment Share on other sites More sharing options...
richarde7927 Posted November 20, 2010 Share Posted November 20, 2010 As it started when you were turning , i would say the diff maybe . drop the diff oil into a clear container and see if there is loads of metel in the oil . Rich. Quote Link to comment Share on other sites More sharing options...
Guest lasneller Posted November 20, 2010 Share Posted November 20, 2010 Double check the rear anti-roll bar. Could be knocking against dampers Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 20, 2010 Share Posted November 20, 2010 (edited) The CV joints are at each end of the driveshafts, between the diff and the hub. Does the banging alter with speed or if you brake ? Does the car still brake and accelerate without pulling to the left or right ? Did the wheels rotate freely ? 1 Milimeter of play is huge in a wheelbearing so im guessing you mean a chunk less than that Edited November 20, 2010 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
mrgee2jz Posted November 21, 2010 Share Posted November 21, 2010 if its sounds a but like a train, you've broken your diff, done this a few times Quote Link to comment Share on other sites More sharing options...
dude Posted November 21, 2010 Share Posted November 21, 2010 Make sure one of the rear calipers is not seizing up when it gets warm, just had one do this and sounded just like the diff was dead. Quote Link to comment Share on other sites More sharing options...
Mike17 Posted November 22, 2010 Author Share Posted November 22, 2010 Thanks for your replies dudes! It's definately not the wheel nuts they are all find so we can rule that one out...I'm just going to get it to a garage and ask them to have a look, it's all so complicated lol Don't suppose anyone can recommend a good garage around Bristol/Gloucester/Cheltenham/Cardiff way? Itsso difficult to find one that doesn't do a sharp intake of breath when they know it's an import lol Quote Link to comment Share on other sites More sharing options...
nevins Posted November 22, 2010 Share Posted November 22, 2010 Had a similar problem with mine, there were a few possible causes that were all done at the same time. The garage left my spigot ring off, also check for play in your upper and lower arms. Also as dude said check if your callipers have a sticky piston. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 22, 2010 Share Posted November 22, 2010 if you want to bring it to cardiff , ill have a look over it for you. im sure nevins wiould like to pop down to Quote Link to comment Share on other sites More sharing options...
nevins Posted November 22, 2010 Share Posted November 22, 2010 if you want to bring it to cardiff , ill have a look over it for you. im sure nevins wiould like to pop down to Im up for this, will give it a going over for you fella, and find out whats at fault. Quote Link to comment Share on other sites More sharing options...
nevins Posted November 22, 2010 Share Posted November 22, 2010 Come to think of it craig I need to borrow your ramp for 20 mins, got a nismo cat back to fit to the 14a. Edit, did you get a ramp after or am I thinking of someone else getting one lol Quote Link to comment Share on other sites More sharing options...
mrgee2jz Posted November 22, 2010 Share Posted November 22, 2010 best way to test is get it up in the air and spin each wheel seperatly and see if it spins freely, then try it with it in park or in gear if its a manual. if the diffs broke youll get to a point where it starts crunching or getting stuck. if not you may feel the calipers binding. and have a look at the rear axle, your diff may be hanging off Quote Link to comment Share on other sites More sharing options...
Mike17 Posted November 23, 2010 Author Share Posted November 23, 2010 Wow you guys are so nice , thank you so much!! Where in Cardiff do you hang out? We've had a couple if problems with it since we've had it back on the road, the speedo is not working and the o/drive light randomly flashes for no apparent reason!! Neither me or my husband are any good at all with cars and people in garages seem to know this and scare us to death that the whole thing is going to self distruct and it'll cost a million pound to fix lol it's not really a very good car for us to own really but it's just so pretty lol Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 23, 2010 Share Posted November 23, 2010 pm me for directions and we can arrange a time with nev Quote Link to comment Share on other sites More sharing options...
