Alloy wheel sizes - little advice/help
evinX
Hey all, would like some advice on some wheel and tyre sizes, the ET are my main concern, the stock ET is 50, so should i be going for the ones closest to 50?
Front, sizes available, which ones should i get?
18",width 8", holes 5, PCD 114mm, ET 30mm
or
18" width 8", holes 5, PCD 114mm, ET 42mm - Im thinking i should go for these?
Rears, sizes available, which ones should i get?
18", width 9.5", holes 5, PCD 114mm, ET 38mm
or
18", width 9.5", holes 5, PCD 114mm, ET 42mm - Im thinking i should go for these?
Tyres, would these sizes i picked for the front be ok and which rears should i go for?
Fronts, 235/40/18
Rears, 255/35/18 or 265/35/18
thanks, Kevin
Edited by evinX (see edit history)
If you use an online offset calculator you can work out how much further out the wheels will sit than either the ones you have on now or stock.
Just put in your current wheel specs and put in the new ones and you'll see how many mm they stick out and how it affects clearance for the brakes etc too. Can go off mine if you want a very flush fit (take 60mm off the rears though) 18x12et0 (rears) 18x9.5et25 (fronts)
