RobSheffield Posted November 19, 2010 Share Posted November 19, 2010 I have a -8 line from tank area to an Aeromotive -8 filter to a -8 to twin -6 feed Y piece with 2 -6 feed lines, -6 return line to FPR and also an Aeromotove FPR All braided lines, i had been using the stock return so no return from FPR to tank. £350 all in, plus delivery. Pics later today. Link to comment Share on other sites More sharing options...
johnny g Posted November 19, 2010 Share Posted November 19, 2010 Will these need a stock rail to be tapped for dual-feed? Link to comment Share on other sites More sharing options...
RobSheffield Posted November 19, 2010 Author Share Posted November 19, 2010 Will these need a stock rail to be tapped for dual-feed? If its a stock rail you are using then yes, or use an aftermarket rail, or alternatively remove the Y piece and just go -8 to -6 single and run single feed. Link to comment Share on other sites More sharing options...
Stephen G Posted November 20, 2010 Share Posted November 20, 2010 Are you open to offers? Link to comment Share on other sites More sharing options...
hodge Posted November 20, 2010 Share Posted November 20, 2010 Will these need a stock rail to be tapped for dual-feed? Your better off just drilling the Rail and welding the fitting on Johnny. I've done it a few times. Run the polishing mop over it an it looks like it was ment to be there. Link to comment Share on other sites More sharing options...
RobSheffield Posted December 9, 2010 Author Share Posted December 9, 2010 Sold Link to comment Share on other sites More sharing options...
