Noz Posted November 18, 2012 Share Posted November 18, 2012 Sounding good mate Link to comment Share on other sites More sharing options...
JasonR24 Posted November 18, 2012 Share Posted November 18, 2012 Sounds awesome! (there's that word again ) Link to comment Share on other sites More sharing options...
David P Posted November 18, 2012 Author Share Posted November 18, 2012 Sounds awesome! (there's that word again ) From kids to old fogies, 'Awesome' has been unanimous, except for Noz, who only rates it as 'good'. Link to comment Share on other sites More sharing options...
Herb Posted November 18, 2012 Share Posted November 18, 2012 Awesome! Link to comment Share on other sites More sharing options...
David P Posted November 18, 2012 Author Share Posted November 18, 2012 Awesome! There it is again cheers Herb, it's an Awesome daily thruster. The sound of a supercharger behind, intimidates most drivers out of the way and Dual Carriageway driving is like a 'Parting of the Red Sea'. Many of those who've been 'Stuka'd' before pull over when they hear me coming and wave me on so they can listen to the supercharger Howl as I go past. Link to comment Share on other sites More sharing options...
David P Posted November 18, 2012 Author Share Posted November 18, 2012 (edited) I ran out of daylight and didn't get the bracket finished today but have the bare-bones of it together, which is the fiddly-est bit out of the way. Edited November 18, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted November 27, 2012 Author Share Posted November 27, 2012 (edited) Good news is; I have an ERL MF2 ECU to upgrade the water/meth system. Bad news is; For compatibility it requires a 2 Bar sensor and I have an AEM 1 Bar and 3 Bar but not 2. If any one has a 2 Bar AEM to sell or swap for a 1 or 3 please contact me. Thank you. Edited November 27, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
Wez Posted November 27, 2012 Share Posted November 27, 2012 Does the AEM 2bar sensor have the same calibration as the 2bar sensor normally used with the MF2? Link to comment Share on other sites More sharing options...
David P Posted November 27, 2012 Author Share Posted November 27, 2012 (edited) I haven't studied the manual yet, but the Tech Guru at Aquamist informs me that it won't function with the 3 Bar and I need a 2. I think all 2 Bar MAP sensors have the same voltage range. https://docs.google.com/viewer?attid=0.1&pid=gmail&thid=13a98ad2c307aac2&url=https://mail.google.com/mail/ca/?ui%3D2%26ik%3D199ae3679f%26view%3Datt%26th%3D13a98ad2c307aac2%26attid%3D0.1%26disp%3Dsafe%26zw&docid=67c779288fbb3a31f04793c904fe6118%7C0a8531ba9468149f2f16401dc3cde976&chan=EwAAAPvcRyyURfnfrX5YWG9WGJySrnJjIXQKUUkebQtQJT2M&a=v&rel=zip;z1;manual.pdf Edited November 27, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted November 28, 2012 Author Share Posted November 28, 2012 I managed to gain access to outside the Workshop this afternoon, but further to to bracket job there was some maintenance to attend to. The Mcguard locking wheel nut key had broken off in one of the nuts and getting them off used up most of this prime time, if you have a set of these, I suggest you give them to someone you don't like. The loose baffle in the exhaust was then cured with a few well aimed clonks with a ball pein hammer, which left only a few minutes of chilly daylight to tinker with the bracket. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 28, 2012 Share Posted November 28, 2012 Been though more than half a dozen of those wheel nut keys, awful things. Use an impact gun on them at your peril. Over torque the at your peril, use them more than once a year at your peril. Bin them and be able to get the punctured tyre off on the side of a wet road.. As for the bracket, Damien Hurst should be worried, he has a competitor Link to comment Share on other sites More sharing options...
David P Posted November 28, 2012 Author Share Posted November 28, 2012 A crock of guano and gratefully binned, it makes you wonder how they were ever OE approved. This bracket will be a sky-hook work of art, when it's eventually finished. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 28, 2012 Share Posted November 28, 2012 You have to admit though, they are an excellent wheel removal obstacle You'll be needing a smaller SC pulley soon, just to keep up with all the metalwork you are nailing on Link to comment Share on other sites More sharing options...
David P Posted November 28, 2012 Author Share Posted November 28, 2012 Without the bracket the belt pulls 12lbs of boost and with it 15lbs, so that should make the 1lb of steel worth it. Link to comment Share on other sites More sharing options...
David P Posted November 29, 2012 Author Share Posted November 29, 2012 (edited) The adjustable two-piece sky-hook 15lbs boost-bracket is born. It might need a tricky triangulation of the top stay, yet will nail it on tomorrow then find a belt that fits and give it a whirl to find out. Edited November 29, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted December 1, 2012 Author Share Posted December 1, 2012 (edited) As if this bitter weather was not task enough, I managed to trap my finger in the car door and as well as a dreaded black fingernail, the whole end of my digit has decided it's a blood blister. Now the sky-hook bracket is fitted, it blends in amongst the other contraptions and looks as though it might be up to the task without further tinkering. It's a simple job to change belts, which is a good thing because I'm on my third different length belt trial fit. The belt shown is a Gates 2563, yet it's almost too long and would be after the initial-stretch so need to order the next size or two down. Because this idler is so close to the supercharger pulley it's very fussy to be perfectly aligned. Being a digit down didn't help matters, yet have adjusted it by eye and trial and error into the position that runs the belt true. Before swapping back to the previous belt and configuration I gave it a blip and WOW, no slip and the sound of the charger is completely different, I can only describe it as an 'instant trouser department' noise. Here's a clip with the new max-wrap configuration at tick-over, this new charger is clattery when cold, yet sweet as a nut when warmed up. Edited December 3, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted December 2, 2012 Author Share Posted December 2, 2012 After a night of Gremlins beating my poorly finger with a hammer in time with my heart beat, today I trapped it again between a handle and bucket, and it clicked. It turns out that the end of my digit is broken and was misaligned, fortunately, the bucket mishap has reset it straight and my fingernail now has a trendy go faster stripe to remind me to let it get better. Link to comment Share on other sites More sharing options...
Noz Posted December 2, 2012 Share Posted December 2, 2012 Looking good David. Keep up the good work. By the way David, where you going for new year? Think I might actually be coming up that way for NYE. Link to comment Share on other sites More sharing options...
David P Posted December 3, 2012 Author Share Posted December 3, 2012 (edited) It's booked in for a remap on 13th December, so as long as my go-faster stripe doesn't prevent me from finishing the go-faster list I'll sink your eyes into their sockets. If you make it, I'll meet you for a pint of 'Heavy'. It's called 'Hogmanay' there. Edited December 4, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted December 3, 2012 Author Share Posted December 3, 2012 (edited) I've commissioned another 4" supercharger pulley fabricated with cross-hatches, ordering a couple of different length Gatorback belts and a can of anti-slip juice. With the new max-wrap idler, belt, braces and snake glue, 15lbs of boost will soon be mine. The upgraded valve-body which has been modified to alleviate the P to D bump, increase line-pressure and speed up gear-changes is winging it's way too, count-down to the 13th begins. Edited December 4, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted December 3, 2012 Author Share Posted December 3, 2012 (edited) I have found a remarkably efficient local supplier of Gates belts. Order by telephone before midday and whatever belts I want are delivered to my door by 4.30pm! Amazing service from CT Autoparts, Kettering. Straight exchange or full refund for any belt(s)s found unsuitable and at discounted trade price too. Today I exchanged the Gates 2563 belt that was almost to long, for a 2550 & bought a 2535 for trial fittings. I'll have a go tomorrow, yet I'm concerned to break my finger-end in the cold again, these Gates belts are a lot stiffer to weadle about and crispy to handle, compared to the softer and much easier and nicer to work with Gatorbacks. As soon as I have identified the length(s) needed, I'll order a couple of Gatorback 4061005 and/or 4061000 from the U.S. They're £8 each, bought in two's and shipped for the price of one, with a total value below reach of Robbing Tax Hoods itchy fingers. Edited December 4, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted December 4, 2012 Author Share Posted December 4, 2012 (edited) 50% belt-wrap on 6.78" crank pulley = 10.5" 80% belt-wrap on 4.2" supercharger pulley = 10.5" = 13lbs boost. 80% belt-wrap on "True Gripped" 4" supercharger pulley = 10" = 15lbs boost. This guess-measure-y equation shows the drive-train is up to full capability. Should Sky-Hook Bracket Mk1 prove fit for purpose, I'm confident it'll now have sufficient traction to boost 15lbs. Edited December 4, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted December 4, 2012 Author Share Posted December 4, 2012 (edited) Weather Underground says "zero probabilty of rain", yet it's lashing it down out there. I'm peering out of the window itching to get on with some of the final little jobs and my finger is signalling to me in Morse code. -.. --- -. ----. - / -.. --- / .. - ("Don't do it") Edited December 4, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
Guigsy Posted December 4, 2012 Share Posted December 4, 2012 It doesn't rain much underground. That's probably where the 0 chance comes from. Nice and sunny over here Link to comment Share on other sites More sharing options...
David P Posted December 4, 2012 Author Share Posted December 4, 2012 (edited) It has brightened up a bit and I've trial fitted the new belts. It's the Gates 2551 or a Gatorback 4061005 that's the required size. I'll get a couple of 4061005 Gatorbacks ordered, and swap the Gates 2359 for another 2551. Then I'll have at least managed to get one little job off the list, and without getting into trouble with my digit either. Edited December 4, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
