Project Supracharger
David P
  • Replies 1.9k
To be fair, that should be your next route when you've got the charger sorted. I reckon that would be alot easier though. Maybe not as easy as expected, with that custom overhead intake the manifold might sit the turbo a bit high. Plus might be overkill for a daily at that point.
If you need anything CNC turned give me a shout :)
I have access to a big lathe and made the first few attempts myself, only to learn that I couldn't reverse the adaptor in the chuck and machine both ends to run true.
Wanting to get on, I gave the job to a 'professional' and explained these details, yet apparently he couldn't do it either. :shrug:
David, there is a guy in Irchester who has a small machine shop who would undertake this sort of thing for you.
Now you tell me now it's all just about done. :shrug:
Thanks anyway. :)
The only space for a turbo would be at the back, but that would then create too much boost for stock compression and defeat the whole object of the exercise of using a stock unopened GE engine and would also exceed the power the A343E box could manage.
There will be enough grunt as it is, for an Old Fart. ;)
At this spec, if an engine or gearbox should fail, a replacement for either can be picked up for £100 or less.
At last, I have the PAS bracket components back from the Engineer. :)
This time, the adaptor runs true and both the wheel and adaptor have matching 45° male/female faces to locate centrally.
Not much to look at, but as long as they work like in my minds eye :think: the project can move forwards.
Female adaptor and male centre boss @ 45°
Wheel-nut technology :think:
This afternoon I fitted the new PAS support components and all seems almost well enough. :think:
There is a gentle 'growl' from the bearing and the pulley is not running as true as when in the lathe.
I suspect the pump-shaft was bent :limp: by my previous attempt to prevent it from bending, :shrug: so I will swap the PAS pump for another one I have stashed.
Today I changed the PAS pump for another and the wheel is now running true. :)
However, the new adaptor is running on the wonk. :(
:shrug: The Engineer promised me this adaptor ran true :think: but it's about as straight as a dogs hind leg. :looney:
This flatulent little job is urinating me off. :taped:
The new pulley wheel showed a good wobble when on the previous PAS pump, yet runs true on the replacement pump, the previous pump was definitely bent by my previous attempt.
The new bent adaptor on the old bent shaft almost ran true, that's the assembly shown in the previous vid-link, now functioning. :blush:
On the new pump the new pulley wheel runs true, but the adaptor is too wonky to even consider assembling the bracket.
I have no issue with belt run-out, the issue is getting the double-shear PAS pump bearing to run without killing itself and/or another PAS pump-shaft.
After being dicked about for nearly six months now discovering at my expense that at least four of the local Engineers are merely monkeys with machines.
I bundled all of their cock-ups, along with 3 PAS pumps none with a true shaft and 8 PAS pulleys with wonk various and the bracket into a box ready to try and find if there is an Engineer in the country who can actually do what he's paid for!
Then it occurred to me to pick and mix from this shambles to try and find if the angle of the dangle might equal the swerve of the curve. :think:
Using only eye and feel, I have mixed and matched these wonky components in a myriad of orders and positions and found a combination that the bearing in the bracket is 'happy' with.
I am not satisfied with the job and will continue the hunt to find an Engineer who can actually engineer, yet will let this mongrel have a go for now so I can move on with the project.
There's one item of red ink on my to-do list that someone might be able to help me with.
I need an old laptop that runs 'Hyperterminal' to reinstall and program the Suprastick ECU, I can't get this program to operate with Windows 7 but I think it's standard in Windows 95?
