David P Posted February 5, 2012 Author Share Posted February 5, 2012 (edited) The plan for today was to confirm the new belt is the correct length, shim the top idler true and trial fit the N/A throttle cable to the bespoke linkage. But have chosen to pass on freezing my previously frost bitten fingers and dropped nuts disappearing into the snow. Pic of my new Borbet TTE wheels. Edited February 9, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted February 16, 2012 Author Share Posted February 16, 2012 (edited) Good news; I final fitted the cable/bracket/ramp, everything lines up nicely and just goes in. Bad news; The N/A cable is too long, so will need to make another. Good news; I have shimmed the top idler pulley to run true. Bad news, the new belt is still too short and have found the steel OE idler pulley on the tensioner is about 25thou out of round, see the chatter it's causing @ 9 seconds. Edited February 16, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
Noz Posted February 16, 2012 Share Posted February 16, 2012 Bad news! Will you try and re machine the pulley or make a new one? Link to comment Share on other sites More sharing options...
David P Posted February 16, 2012 Author Share Posted February 16, 2012 (edited) Just need an unabused OE steel idler pulley. Edited February 16, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
lexmk4 Posted February 16, 2012 Share Posted February 16, 2012 Sorry about the bad news, but you are doing an awesome job!! Link to comment Share on other sites More sharing options...
David P Posted February 16, 2012 Author Share Posted February 16, 2012 (edited) Thank you for the compliment. That's typical progress, doing two jobs allowed me to find that there are actually three more jobs to do to get to where I thought I was going to get to. I don't like the gas strut tensioner either, so making an adjustable spring loaded Mk2. Edited February 18, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
straightsix Posted February 16, 2012 Share Posted February 16, 2012 Which pulley do you need? I've just taken my old engine apart.... Link to comment Share on other sites More sharing options...
David P Posted February 16, 2012 Author Share Posted February 16, 2012 Just need an unabused OE steel idler pulley. Thanks for the kind offer, but Shane has one I can have. Link to comment Share on other sites More sharing options...
Benjy Posted February 16, 2012 Share Posted February 16, 2012 I was dead set on making my SZ-R a TT6, but now I want this. lol Link to comment Share on other sites More sharing options...
Noz Posted February 17, 2012 Share Posted February 17, 2012 When he has this running it's going to bed nuts. Highest powered stock compression NA running on the forum I expect. Aiming for 14psi aren't you david on stock HG? Gonna be evil... with stock compression so no low comp lag and a charger kicking in low, this thing is gonna be nuts. Are you going to be doing ride's at Pod David? Link to comment Share on other sites More sharing options...
David P Posted February 17, 2012 Author Share Posted February 17, 2012 (edited) Here are some of the specifications, it'll be interesting to see how it performs in the real world. Eaton M112 - 112 cu in (1835cc) per rev ATI crank pulley 6.78" - supercharger pulley 4.2" Max RPM - engine 6,800 - supercharger 10,977 Air flow - 13.56psi - 711 cfm - 57.4 Lb/min (0.93 bar - 20,147 lpm) Compression - static 10:1 - dynamic 16.94:1 Denso 550cc high imp injectors - U.K. spec 299lph fuel pump Water/meth 50/50 - one 0.4mm jet pre-supercharger - three 0.4mm jets post-cooler @ 15% fuel parallel Air-to-water charge-cooled Hydrogen @ 6 lpm I am planning to run it at Suprapod, then we'll know. Edited April 16, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
Noz Posted February 19, 2012 Share Posted February 19, 2012 You got the charger intake hooked into the engine then? Time for mapping soon? Link to comment Share on other sites More sharing options...
David P Posted February 19, 2012 Author Share Posted February 19, 2012 (edited) Here are the known remaining jobs and things, I'll keep this compilation up-dated for reference and just in-case you think I'm slacking. Progress Gasket match inlet-ports, remove ACIS vacuum system, fit runners and filter-block bobbins. (Done) Fit modified rocker-cover and final-fit the charge-cooler to the stock cover on car engine. (Done) Find another OE steel belt-tensioner idler-pulley, confirm that it's circular and swap it on. (Done) Fit new top wishbones, C.W suspension, DBA discs 5k front, 4k rear and C.W. pads.(Done) Fabricate, fit and test spring-loaded adjustable Mk2 secondary belt-tensioner. (Done) Relocate water-gauge temp-sensor from top-hose to charge-cooler. (Done) Fetch another N/A throttle-cable from Keron and shorten to suit. (Done) Fit silicone elbows & straight-connectors to charge-cooler. (Done) Refit supercharger to discover the correct length belt. (Done) Make a sturdy bracket for exhaust manifold flange. (Done) Sort out electrickery for HHO w/m & C-C pump. (Done) Fit stainless bolts - nuts - washers - anodes. (Done) NGK BP6ES copper-core non-resistor plugs. (Done) Relocate w/m pump to spare-wheel well. (Done) Fit pump for HHO and plumb the system. (Done) Seal the inside of leaking rocker cover. (Done) Fit 550cc high-imp top-feed injectors. (Done) Fit bespoke water-pump idler pulley. (Done) Modify and fit clear cam-belt cover. (Done) Modify the H.T. leads to fit. (Done) Change 5W/50 & oil filter. (Done) Rebuild leaky generators. (Done) Fit Hydrogen generators. (Done) Fit w/m booster pump. (Done) Fit new top idler-pulley. (Done) Upgrade PAS bracket. (Done) PAS support adaptor. (Done) Fit throttle cable. (Done) Fit HHO controls. (Done) Fit mid-pipe. (Done) Mapping day Wednesday 25th July. Edited July 25, 2012 by David P Updating (see edit history) Link to comment Share on other sites More sharing options...
ScottC Posted February 20, 2012 Share Posted February 20, 2012 You're the last man standing. May the force be with you Link to comment Share on other sites More sharing options...
David P Posted February 26, 2012 Author Share Posted February 26, 2012 (edited) H.T. 'Force' is strong in me and leads are off the list. Before: Coil to distributor not long enough and 3 plug leads too long After: The shortened plug leads lay much better Coil lead replaced with longer and rerouted to clear supercharger snout and throttle mechanism Tight & tidy on the pre 92 V6 4Runner cap makes space for supercharger snout Edited February 15, 2014 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted February 28, 2012 Author Share Posted February 28, 2012 (edited) A couple of jobs off the list posted a couple of posts ago and a few hard-earned bits & bobs & things & stuff compiled again. Victims hunted down for the adjustable spring-loaded secondary belt-tensioner I can see in my minds eye. M10 male and M8 female rose-joints found on ebay A likely looking 3mm spring found on ebay too M16 threaded tube from ironmongersonline M16 half-nuts from local Ironmonger Long M8 bolt found under Kerons' bench Stainless-steel billet-end from local engineers scrap box (Need a couple of O-rings) Edited March 6, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
lexmk4 Posted February 29, 2012 Share Posted February 29, 2012 i love all the custom fab work Link to comment Share on other sites More sharing options...
Noz Posted March 2, 2012 Share Posted March 2, 2012 How easy were the HT leads to modify? Link to comment Share on other sites More sharing options...
David P Posted March 2, 2012 Author Share Posted March 2, 2012 (edited) I have discovered that a friends uncle has the correct crimping tool for the old type of connectors and using that it was easy-peasy. Don't even think about attempting this job without the correct tool. Edited March 3, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
Noz Posted March 2, 2012 Share Posted March 2, 2012 I reckon a decent set of pliers would do it Link to comment Share on other sites More sharing options...
David P Posted March 4, 2012 Author Share Posted March 4, 2012 (edited) Bespoke additional spring-loaded tensioner, adjustable from zero to 20kg. One more job crossed off the list. Edited March 4, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
Noz Posted March 4, 2012 Share Posted March 4, 2012 custom made? Link to comment Share on other sites More sharing options...
David P Posted March 4, 2012 Author Share Posted March 4, 2012 (edited) The weather was too bad to work outside on the car today, so I tinkered about inside the workshop and fabricated the secondary tensioner from the components pictured a post or three before. Edited March 12, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted March 10, 2012 Author Share Posted March 10, 2012 (edited) The secondary "custom made" tensioner fits and functions nicely, It will need a guide to keep the spring straight under tension and a couple of nylocks for the final fit. Throttle cable Mk2 is off the job list too. Edited March 18, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted March 12, 2012 Author Share Posted March 12, 2012 (edited) I am working my way through the active job list and need an OE steel idler pulley, there must be plenty of those gathering dust. If you have one of them, please contact me. Edited March 12, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
