David P Posted April 11, 2011 Author Share Posted April 11, 2011 (edited) That's the second scoop/cowl you have turned up Barney, nip out and lay a mould onto a Land Rover Puma bulge and I will accept your third offer. The transmission line feed pressure cable needed to be 185mm longer to reach the supercharger Lexus throttle body and one has been ordered from Speedograph Ritchfield, as soon as I have this cable, the transmission fluid and some 6mm nylon hose for the water/meth feed, the hybrid can go in. Edited April 12, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted April 12, 2011 Author Share Posted April 12, 2011 (edited) Speedograph Ritchfield require 2 weeks to do a 5 minute job. Redline DS4 is now only available in Europe packaged in baby bottles. The 6mm nylon pipe for the water/meth is green. A wind-up 'Hat-Trick'. I hope that means the job will go like clock-work. Edited May 19, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted April 13, 2011 Author Share Posted April 13, 2011 (edited) Without the cable, it looks like I won't be changing the transmission this weekend, so instead have made up the 2 x Jaguar X300 pre rads back-to-back into one unit, using Supra radiator rubbers to mount the pre rad legs to the bracket and the top mounts are Jag rubbers with sleeve spacers and body washers. Will begin fitting these and the aluminium shelf for the HHO generators and 2 electric pumps. It's going to be busy up front, maybe I need to look at extra ventilation options. Edited May 19, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted April 16, 2011 Author Share Posted April 16, 2011 (edited) I have been off line for the last 2 days, I downloaded IE8 but it lost text recognition? This was surprisingly difficult to sort out, now using Google Chrome as the workaround. The cable, oil and pipe have all turned up. The Hybrid now has a longer cable and is built up ready to go in. Plumbed in the water/meth system on the jig engine, but will need to adjust the position of distribution block to make room for the boost gauge sensor. Back-on-schedule for the transmission and drive-line change tomorrow. Edited April 17, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted April 18, 2011 Author Share Posted April 18, 2011 (edited) The deed is done, the Hybrid A343/0E is in and working perfectly in both auto and manualised mode with the Suprastick. Also fitted the 3.769 Torsen, T.T. auto prop, removed the unused fuel breather pipe and replaced it with the water/meth pipe. The operation of this transmission is more positive and the N/A engine doesn't seem to mind the taller gearing. Edited April 18, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted April 19, 2011 Author Share Posted April 19, 2011 (edited) Fitting N/A hydraulic control to the Hybrid seems to have raised the line pressure, I don't know by how much, but first chance I get, I will test it and see. It needs a little 'respect' when moving from Park into Drive. It has a likeable character, that is keen to get going. Pausing in Reverse for a second 'tames' this and gives a stockish engagement. Driven slow to moderate, the shifts are smooth as stock, yet when driven harder gives firmer auto shifts and faster manualised gear changes. I am really chuffed with the creation of this Hybrid, this is the first time this has been achieved and also a crucial major component of the project. Now the transmission related upgrades are completed, I can update the Suprastick programming with the changed diff ratio, tyre size, torque converter lock-up, shift speed, firmness and shift tables that best suit this unit. It will be even better after that's done. Edited April 21, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted April 19, 2011 Share Posted April 19, 2011 great news mate! glad to here things are coming together. one step closer to the goal! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 19, 2011 Share Posted April 19, 2011 Good work How will you adjust/control the line pressure, is it manual or electronic? Quote Link to comment Share on other sites More sharing options...
David P Posted April 19, 2011 Author Share Posted April 19, 2011 (edited) great news mate! glad to here things are coming together. one step closer to the goal! That was one large and very important step closer and an achievement ranking equal to the supercharger conversion. Should my Hybrid hydraulic theory have proven wrong, it would have grounded the project. It is 'curious' that this achievement may have been unrecognised by many and unnoticed by others? Nevertheless, I am happy that this messy, smelly, oily, skatey antipodean job is jobbed. This Hybrid unit with raised line-pressure, should be good for 600 ft lbs or more? and more than strong enough for the job. Only the pre rads and alloy shelf to go in and the 'underneath' jobs are done, it should be steady stand up tinkering from there on in. Edited May 19, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted April 19, 2011 Author Share Posted April 19, 2011 (edited) Good work How will you adjust/control the line pressure, is it manual or electronic? Only 4 posts previous, there's a full size pic of the Hybrid wearing it's new Speedograph Ritchfield bespoke 185mm longer line-pressure control-cable. Maybe I am going too fast for you to keep up? Edited May 19, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 19, 2011 Share Posted April 19, 2011 Yup its official, Im a dumbass Quote Link to comment Share on other sites More sharing options...
David P Posted April 19, 2011 Author Share Posted April 19, 2011 (edited) Yup its official, Im a dumbass "but not before 6pm". Edited April 19, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted April 22, 2011 Author Share Posted April 22, 2011 (edited) I have been to Keron's to hunt out the final bits needed for the Hybrid, and have swapped the N/A gearbox crossmember and dipstick assembly for T.T. items and checked for leaks. I declare the Hybrid complete and a complete success. Edited May 19, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
BazzaAlpine Posted April 22, 2011 Share Posted April 22, 2011 Nice one Hope I get to see it going down the strip at Suprapod. Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted April 22, 2011 Share Posted April 22, 2011 I'm going to be the dumbass here and summarise for my own sake. Engine and supercharger are complete. The gearbox and flappy paddle shift are complete, except for some tinkering/programming. Has the gearbox been tested on a running vehicle? Is the next step mating the two and seeing what happens? Quote Link to comment Share on other sites More sharing options...
David P Posted April 24, 2011 Author Share Posted April 24, 2011 (edited) I'm going to be the dumbass here and summarise for my own sake. Engine and supercharger are complete. The gearbox and flappy paddle shift are complete, except for some tinkering/programming. Has the gearbox been tested on a running vehicle? Is the next step mating the two and seeing what happens? The supercharger conversion is complete, yet sitting on the jig engine and untested. The Hybrid flappy-paddle T.T. transmission is complete and fitted into the Supra being driven by the N/A lump, tested and working perfectly. Next I will fit the pre rads, water/meth and HHO into the car, then I will be ready to transplant the supercharger conversion into the car. I had planned to fit the pre rads today, but I've had to change the gearbox in a 240Z and build another Hybrid transmission for someone else. Now that other folk's gearboxes are sorted, I will fit them tomorrow and take some pics. I haven't been posting many pics lately, because one gearbox looks much the same as another and I have been blathered in auto-trans fluid from earhole to arsehole and my camera would be bolloxed in a day. Edited May 19, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted April 25, 2011 Author Share Posted April 25, 2011 (edited) I have modified a few pipes and brackets, fitted the two Jaguar X300 pre rads and relocated the power steering cooler. The alloy shelf is ready to go in too, but the thread inserts I have were not suitable. A difficult subject, but here's a couple of pics. Edited July 31, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted April 25, 2011 Share Posted April 25, 2011 Forgive my ignorance about such things, but how is the water in the charge cooling system pumped around? A small inline electric pump, a pump in the body of the supercharger itself? At first I believed if was part of the main cooling system, but seeing those rads im led to believe otherwise? Quote Link to comment Share on other sites More sharing options...
David P Posted April 25, 2011 Author Share Posted April 25, 2011 (edited) The water in the charge cooler circuit is independent, with a swirl-pot header-tank behind the charge-cooler and circulated around the pre-rads with a Bosch 1,200 lph electric pump, there's a pic of it in post 24. I'm not sure where it will be located yet, there's a lot of 'stuff' to stuff in the front, and I need to get the shelf in and the air con pipes out of the way, I can then shuffle these components around to find the best fit. Edited May 19, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted April 29, 2011 Author Share Posted April 29, 2011 (edited) It was Supra Yoga getting the nutserts drawn into the holes, but now the recycled crash-bar shelf is in. I even managed to move the air-con pipes without breaking them too. Edited May 19, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted April 30, 2011 Author Share Posted April 30, 2011 (edited) Today I managed to locate and borrow a pair of crimpers for the old type of HT leads and the pre 92 4Runner cap is on. Now there's sufficient clearance for the supercharger to fit onto the car engine. Edited May 19, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted May 1, 2011 Author Share Posted May 1, 2011 Mmmm, Now the shelf is in, I have been shuffling components around and have decided that access will be too much hassle, so have decided to move the battery to the boot and fit the HHO generators into the space. Quote Link to comment Share on other sites More sharing options...
David P Posted May 2, 2011 Author Share Posted May 2, 2011 (edited) I have found homes for the charge-cooler pump on the chassis rail, the water/meth pump on the inner wing and the HHO water tank in place of the charcoal canister. The pumps are both mounted on rubber bobbins, the tank nestles in the corner nicely and may get just a foam pad and a couple of cable ties? The green water/meth pipe can barely be seen, but think I will sleeve it in black silicone to stop it rattling. I had to make a tag to mount the Hybrid transmission T.T. dipstick onto the N/A manifold, yet it looks as though it belongs there. Edited May 2, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted May 6, 2011 Author Share Posted May 6, 2011 (edited) Today I thought to plumb in the pre rads and get the active spoiler back in, what a Supragarmi nucking fightmare! The pre rads mounting bracket was in conflict with the active spoiler, both the engine and trans oil coolers were in the way, the horn was in the way, all 8 of the HID capacitors were in the way, the towing brackets were both in the way and the repositioned power steering cooler was in the way too. I have modded the bottom mounting of the active spoiler to make room for the bracket, repositioned the power steering cooler and the horn and removed the towing brackets. The pipework is now complete between pre rads and pump, but need another 90 elbow to finish the other side. There was I thinking it was going to be a simple job for a change. Edited May 8, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted May 11, 2011 Author Share Posted May 11, 2011 I have added a third bobbin to the ERL w/m pump mounting and made a little bracket for the first of 2 ECU controlled valves in the system, the 40 amp relay is mounted on one of the tank bobbins and the loom has been gathered up in the corner. All of the wires will end in a heap here then I will sort out all the electrickery together. The w/m tank is to go in the back, this one is both reservoir and flame trap for the HHO system, it will be rattling with bubbles so I have isolated the mountings on 3 bobbins. It took me all day to do this little job and it still requires a final fitting and maybe a fourth bobbin on the tank. I am growing weary of making brackets, relocating and modifying anything and everything, to make components fit and work together. That shiny 6 fingered fist sitting in the workshop will bolt on in a couple of hours, that's the job I would sooner be doing. Quote Link to comment Share on other sites More sharing options...
