David P Posted October 13, 2012 Author Share Posted October 13, 2012 I have tracked down a bearing that will do the job nicely and at £15 this Peugeot 306 cam-belt idler-bearing is a readily-available service item. Now I just need a bracket to hold it here somewhere. Quote Link to comment Share on other sites More sharing options...
Benjy Posted October 13, 2012 Share Posted October 13, 2012 Are you not going for the pinch pulleys effect? Quote Link to comment Share on other sites More sharing options...
David P Posted October 13, 2012 Author Share Posted October 13, 2012 There's almost no difference in the maximum attainable wrap and a single will be easier to fabricate and to maintain. Quote Link to comment Share on other sites More sharing options...
Benjy Posted October 13, 2012 Share Posted October 13, 2012 Wouldn't have thought it'd be too much more effort, seeing as it looks like fabricating a bracket's going to be a PITA anyway? Lol Quote Link to comment Share on other sites More sharing options...
David P Posted October 13, 2012 Author Share Posted October 13, 2012 I've just measured up, it's possible to get around 5mm more, but if sufficient gap is left between them to change a belt without dismantling the pair, then they're loosing. Twins would require a stronger bracket than can be mounted there, it would interfere with the centre-idler operation and make belt changes more complicated. Using a 4.2" pulley and a single idler gains around 38% wrap contact and the 1.5% more with twins is not worth the work and whatever I do will have to be done in an outdoor pit-stop session. When the charger comes off I will fit a modified throttle-body to make space to fabricate the bracket and then rebuild with the new supercharger. I'll get the component parts and pieces as ready as they can be and then wait for a day of workshop access when it's an outside welding kind of day. Quote Link to comment Share on other sites More sharing options...
Noz Posted October 13, 2012 Share Posted October 13, 2012 Whens the remap? Quote Link to comment Share on other sites More sharing options...
David P Posted October 14, 2012 Author Share Posted October 14, 2012 When it's ready. The charger is at the Engineers and the hub is on it's way from the U.S. That gives me time to tinker with a t.b. and prepare component parts for the bracket in between tinkering with the bonnet and other things. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted October 14, 2012 Share Posted October 14, 2012 Sounds good David, the amount of R&D gone into this car is unbelievable, I admire your perseverance! Hope you get it sorted and tearing up the tarmac soon. Ben Quote Link to comment Share on other sites More sharing options...
David P Posted October 15, 2012 Author Share Posted October 15, 2012 Thank you for the encouragement, it tears up tarmac now, when it's not raining. I am meen as kustard to get the final odds and sods sorted, yet I'm being mucked about by all and sundry for the components I need. The constituent pieces for the latest idler bracket are prepared, but can't finish the job until I have a supercharger with a straight hub to work from, so that's grounded for a week or two because it has taken 7 emails over 5 weeks to get one into the post from the U.S. I want to sort out the Suprastick programming yet it has taken 4 weeks for a laptop to arrive and now on the third new wrong charger sent to allow it to function. The fibreglass required to sort the bonnet took 5 weeks to arrive to find the wrong materials had mostly been sent so have had to re-order. I need a reworked valve body to speed up the gear-changes but the chap in the U.S. who modify's them, appears to be incapable of answering to emails for the past three weeks. And so it goes on, there's only a couple of day's work to do to be finished, yet first must endure Global incompetences. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 15, 2012 Share Posted October 15, 2012 I try not to speak to Americans, which I find saves a lot of problems and helps my sanity no end Quote Link to comment Share on other sites More sharing options...
David P Posted October 15, 2012 Author Share Posted October 15, 2012 It would be convenient if I could simply blame it on the Yanks, yet it's apparent that the U.K. also has more than it's fair share of folks who are incapable of doing what they're paid for and whatever the origin, it must still run the Carriers Gauntlet of Hell. Quote Link to comment Share on other sites More sharing options...
David P Posted October 17, 2012 Author Share Posted October 17, 2012 I ordered 2 x M10 1.25 - 38 mm long studs for the new charger rear mounts. However, delivered were; 2 x M12 1.5 studs. Complained. Subsequently, delivered were; 2 x M10 1.5 studs. Complained again. Subsequently, delivered were; 2 x M10 1.25 studs, however, one hasn't been threaded all the way so wouldn't work with the 6mm thick bracket and the threads are poor and damaged on both of them. It looks like I've stumbled into another nest of numpties and for the benefit of my sanity may well end up re-using the old studs. Quote Link to comment Share on other sites More sharing options...
Noz Posted October 17, 2012 Share Posted October 17, 2012 Lol funny Quote Link to comment Share on other sites More sharing options...
Benjy Posted October 17, 2012 Share Posted October 17, 2012 Think I may have the studs you need. Will dig them out tomorrow and PM you. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted October 18, 2012 Share Posted October 18, 2012 Could you not get some bar and knock them up yourself? It really is very simple to do and tap and die sets are not expensive. You'll always have the set then and they are very useful for tidying up slightly damaged threads? Quote Link to comment Share on other sites More sharing options...
Noz Posted October 18, 2012 Share Posted October 18, 2012 OH MY GOD, I COULD MAKE THESE? I COULD FINALLY GET ON THE CHARGER PROJECT HELP LIST :d:d Quote Link to comment Share on other sites More sharing options...
David P Posted October 19, 2012 Author Share Posted October 19, 2012 (edited) Thank you for the stud offers, they're greatly appreciated. The ones used previously were from Bob's stash but I have used up all four there were in that size, I realise I could buy a die and make them yet thought it would be cheaper and simpler to simply buy a couple. I use new each time, because one is so awkward to get at, it's essential that the nuts can be wound up to contact with one finger, then it only takes two nips with 'The only Spanner in the World' that will reach. The new charger is still with the Engineer and the pulley-hub is still winging it's way from the U.S.A, yet most of the fibreglass materials are here and expect the last of it to arrive today. I'll post some pics of bonnet bulging progress when there are some results to be seen. Edited October 19, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 19, 2012 Share Posted October 19, 2012 (edited) Why don't you just buy some high tensile threaded rod and use that for the studs? Die cutting threads is dreadful. Emergency use only, threads should be rolled really. I did say right at the beginning of this project the belt drive was inadequate and would be something that would need a total rework. I still say the same, it needs totally redesigning. I would run a dedicated S/C drive belt, and a wider one, to boot. The whole current set up is too flexible and wimpy. Sorry, but there you are Edited October 19, 2012 by Chris Wilson (see edit history) Quote Link to comment Share on other sites More sharing options...
Benjy Posted October 19, 2012 Share Posted October 19, 2012 (edited) Are these of any use? Edit: Really bad internet at the garage, call me if you need to. 07702 341414 Edited October 19, 2012 by Benjy (see edit history) Quote Link to comment Share on other sites More sharing options...
Noz Posted October 19, 2012 Share Posted October 19, 2012 I've been beaten to it again Quote Link to comment Share on other sites More sharing options...
David P Posted October 19, 2012 Author Share Posted October 19, 2012 (edited) Ben, They're perfect, the only problem is; Noz'll never speak to me again. Thank you, I'll give you a call. The bonnet I spent 3 days stripping the outside, I have now opened up the inside to become a mould. Stripped to the etching primer, flatted down with 1200 grade, polished with Brasso then given 10 layers of Carnauba wax polish Two layers of gel-coat One layer of 450gm mat and another of 600gm then left to cure at regulo .5 until tomorrow Edited October 19, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Benjy Posted October 19, 2012 Share Posted October 19, 2012 They're perfect, the only problem is; Noz'll never speak to me again. Ahhh don't worry about that, I'm the one with the studs! lol Sorry Noz! Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted October 20, 2012 Share Posted October 20, 2012 I'm liking the woodburner Quote Link to comment Share on other sites More sharing options...
David P Posted October 20, 2012 Author Share Posted October 20, 2012 (edited) The mould worked a treat Pruned to fit The carnage begins The blue paint is as thick as the fibreglass Located and ready to glass in The wood burner is fired up again and after my Chinese take-away breakfast/dinner I will do some more. Edited October 20, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Noz Posted October 21, 2012 Share Posted October 21, 2012 What you doing with the small vent? Quote Link to comment Share on other sites More sharing options...
