David P Posted July 28, 2012 Author Share Posted July 28, 2012 (edited) Betterments remaining for the rebuild Modify the Chargespeed bonnet. Locking Aero-Catches fitted Get the HHO up-to-speed. Edited September 9, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
Noz Posted July 28, 2012 Share Posted July 28, 2012 how much do cam covers go for. ive one on my spare engine? i reckon i could engineer something to clamp mesh for your ICV too Link to comment Share on other sites More sharing options...
David P Posted July 28, 2012 Author Share Posted July 28, 2012 (edited) Cheers Noz, I have the cover I took off which I'll try, yet I fear I may need to buy a brand spanker to be clean enough metal to be welded? I am researching ICV's used for supercharger installations and hunting the most 'Macho' version of the options. When I have found what I seek, it would be a help if you could fabricate a custom sized fine-mesh Tetley tea-strainer in 304 grade stainless. Edited July 28, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
sdistc Posted July 28, 2012 Share Posted July 28, 2012 Sorry to see you had issues, but sounds like it's the price of progress. Good luck, and keep up the sterling work! Link to comment Share on other sites More sharing options...
Noz Posted July 28, 2012 Share Posted July 28, 2012 I use 316 grade stainless. It's better corrosion and has less chance of pitting. It's also a better grade for welding, an all round better grade. I would of thought some sort of tube with a ridge inside allowing to mount a cover of some sorts would be perfect? keep me posted. Regarding the cam cover, the cost of time to sand it and clean it enough for a good weld would be alot cheaper than the difference of a new one I would of thought? Link to comment Share on other sites More sharing options...
David P Posted July 28, 2012 Author Share Posted July 28, 2012 (edited) 316 sounds good to me, I will let you know exactly what I need as soon as I know what that is. The cam-cover was a bad one from birth, it's weeping oil through in many places, polishing it has broken the skin and it's weeping through the poor casting that's like a 'Wispa Bar' with the skin rubbed off. I haven't had a chance to look at the other one as I've been busy with more important things. Edited July 28, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted July 29, 2012 Author Share Posted July 29, 2012 (edited) I paid no attention to the charger today, just got on with a few more important jobs, in-between the showers. The Suprastick is out and the Hybrid transmission is being controlled by the N/A auto ECU. Since I made the Suprastick plug&play, it's now also easier to hot-wire the stock system back into play. I have rigged the brake-servo vacuum so it's plug&play for either set up. By replacing the stock clips with Jubilee's I have gained 3mm or more, that will do nicely. I'll go and cross those off the list. The swirl-pot is dismantled and prepared for welding into it's new configuration too. It feels good to get a few of these little jobs off the list, making it a better fit and an easier conversion next time. Edited August 1, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
straightsix Posted July 29, 2012 Share Posted July 29, 2012 I've got a pair of cam covers in the shed that you can have if you cover postage Link to comment Share on other sites More sharing options...
David P Posted July 29, 2012 Author Share Posted July 29, 2012 (edited) Thank you for the offer, the one that came off was a better casting, but I've been busy getting N/A'd again and haven't got around to looking at it. I'll have a good look at it and steam it down first chance I get. You've reminded me that it could be welded at the same time as the swirl-pot. I'll report back. Edited July 29, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted July 30, 2012 Author Share Posted July 30, 2012 (edited) I have blanked with enquiries to Bosch U.K. re. specification of the Idle Control Valves they manufacture, not a single person in their Technical Dept had knowledge beyond a part no. Searching for information on Mercedes Kompressor engines idle control, any links to this information would be appreciated. Here's a pic of the Beefyist-looking option found so far. I was told off for fitting re-sized injectors, so I am on the look-out for 550 or 560cc top-feed high-impedance for a drop-in N/A fit. Any leads to a set at the right price appreciated. Edited July 30, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted August 1, 2012 Author Share Posted August 1, 2012 Found an M112, 80k miles, £179 inc VAT/P&P and a new idle control valve for 99p. Not keen on buying unseen used items, but the price was right. Link to comment Share on other sites More sharing options...
David P Posted August 2, 2012 Author Share Posted August 2, 2012 (edited) I have re-mounted the charge-cooler pump in a non air-lock position, it had to go in a busy place next to the tow hook and it just fits behind the mud-guard. The Renault exhaust bobbins were shot, so I couldn't see the point replacing them and there wasn't space anyway, so it has a foam pad behind and is located with 3 strong cable ties. I have pruned the ears off of the recirculation tail, shortened it and reduced the external diameter, this will allow the hose to be slid back during installation and make the job easier. The cam cover is cut and the new pieces are prepared, this is now soaking in a can of petrol and will give it a good steam clean next time. The supercharger pulley appears to have survived, all of the bend is in the shaft of the M112. Edited August 3, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
JamieP Posted August 2, 2012 Share Posted August 2, 2012 You are certainly dedicated to getting this working David. Link to comment Share on other sites More sharing options...
Noz Posted August 2, 2012 Share Posted August 2, 2012 Whats going on with this custom 'tea strainer' idea. we need to talk about dimensions for inlet and outlet ports so i can begin to design something to consider making this. Link to comment Share on other sites More sharing options...
David P Posted August 2, 2012 Author Share Posted August 2, 2012 (edited) Of all the components that could have failed, it wasn't mine, but one of Mr. T's. Now it has all been on for real I now know all the little pitfalls with the installation, so whilst it's off I am engineering out the fiddly bits. With these final adjustments I should be able to fit it in a couple of hours and any maintenance will be a lot easier too. This contraption will work. Edited August 3, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted August 2, 2012 Author Share Posted August 2, 2012 (edited) My focus has been on getting the car reliably mobile and today was the first chance to tinker with supercharging components. Here's a pic of the job, first I want to have a look at what's about, maybe there's a stainless steel mesh ball that would fit, if not I will post you the elbow for your attention. Edited August 4, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted August 3, 2012 Author Share Posted August 3, 2012 (edited) On my way to the workshop I called into Corby Hose & Hydraulic and unearthed this likely-looking stainless-steel screen water-filter with a nylon fitting. It's welded construction and tough as old boots, it even looks to be a likely size too. Hold still Linda. There was a hole-cutter that just happened to have the same I.D. size as the filter. Reamed to bottom, gave 7mm of squeaky-fit overlap on the slimmer post. Cut to give 7mm post-overlap with nylon shoulder resting on machined surface. Before replacing the O-ring, using a sander levelled the nylon down to the face of casting. Using the dead ICV as a pattern, from a piece of scrap aluminium cut and drilled a cover-plate. Jack the Rabbit and Bob's you're Uncle, for 2 Quid the Job was Bobbed in an hour. Sorry Noz, it just happened. The Portcullis is closed. The Hole of Doom is now the Cage of Hell and the installation won't ever be wiped-out by an errant ICV again. Edited August 4, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
Noz Posted August 3, 2012 Share Posted August 3, 2012 David P said: Sorry Noz, it just happened. ^^ Heard this so many times in my life lol Im pleased it's been a success buddy, though I would love to have taken part in producing custom bits to help out, I'm just glad it's another thing of the list for you. Link to comment Share on other sites More sharing options...
David P Posted August 3, 2012 Author Share Posted August 3, 2012 (edited) Noz, I know you're itching to contribute, thank you. A suitable donor component was easily found for £2 and I was lucky to have the right tools and things to hand, it's nice when a job goes as sweetly as that one. I will go and cross it off the list. The replacement charger turned up today, will collect it tomorrow and see what I have bought. Edited August 4, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
Morpheus Posted August 3, 2012 Share Posted August 3, 2012 (edited) David P said: On my way to the workshop I called into Corby Hose & Hydraulic and unearthed this likely-looking stainless-steel screen water filter with a nylon fitting at one end. http://www.mkivsupra.net/vbb/attachment.php?attachmentid=155670&d=1344013303 It's welded together, tough as old boots and it looks to be a likely size too. "I was working in the lab, late one night, when my eyes beheld an eery sight........ For my monster from his slab began to rise - and suddenly, to my surprise, he did the mesh - the monster mesh!" http://en.m.wikipedia.org/wiki/Monster_Mash http://www.brownielocks.com/monstermash.html Edited August 3, 2012 by Morpheus Linked to lyric and song! (see edit history) Link to comment Share on other sites More sharing options...
David P Posted August 3, 2012 Author Share Posted August 3, 2012 (edited) The "Monster-Mesh Portcullis" T.T. Idle Control Valve Seat Conversion it is then. Edited August 3, 2012 by David P (see edit history) Link to comment Share on other sites More sharing options...
Morpheus Posted August 3, 2012 Share Posted August 3, 2012 David P said: The "Monster-Mesh Portcullis" T.T. Idle Control Valve Seat Conversion it is then. Hopefully it will help protect your Transyl-vane-ia Twist! Link to comment Share on other sites More sharing options...
David P Posted August 4, 2012 Author Share Posted August 4, 2012 There's a used set of injectors on ebay, but the asking price is around same as new before import. http://www.ebay.co.uk/itm/140774659359?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_2378wt_1037 What should I offer on them Chris? Link to comment Share on other sites More sharing options...
neil tt Posted August 4, 2012 Share Posted August 4, 2012 Dave your a star and a legend Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 4, 2012 Share Posted August 4, 2012 David P said: There's a used set of injectors on ebay, but the asking price is around same as new before import. http://www.ebay.co.uk/itm/140774659359?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_2378wt_1037 What should I offer on them Chris? If I am the Chris you are asking I wouldn't offer anything, I always say only buy new injectors. By the time you have had them cleaned and flow tested (I charge £12 each plus VAT) you are getting near to buying new. I am very happy to check them for you, but sometimes it pays to do the maths. Link to comment Share on other sites More sharing options...
