David P Posted June 14, 2012 Author Share Posted June 14, 2012 (edited) Thinking of having the text below or something similar engraved onto the top of the charge-cooler, does anyone have 'Supra' font? 2JZA80-GZE HHO H20/CH30H M-A343/0E A02B Eaton M112 Air-to-Water Charge-Cooled Designed & Built by David Payne Edited June 14, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
LOGIE Posted June 14, 2012 Share Posted June 14, 2012 Stop typing on here and get outside Quote Link to comment Share on other sites More sharing options...
David P Posted June 14, 2012 Author Share Posted June 14, 2012 I am hoping to get at the workshop later today to start getting some of the electrickery and plumbing off the list. Quote Link to comment Share on other sites More sharing options...
Wez Posted June 14, 2012 Share Posted June 14, 2012 Nice work Quote Link to comment Share on other sites More sharing options...
Guigsy Posted June 14, 2012 Share Posted June 14, 2012 It's realy great to see this almost completed Quote Link to comment Share on other sites More sharing options...
Kirk Posted June 14, 2012 Share Posted June 14, 2012 Nice work Mr Payne (top name btw). Engineers do make the best cars don't they Quote Link to comment Share on other sites More sharing options...
David P Posted June 14, 2012 Author Share Posted June 14, 2012 (edited) I have 'made' the joints on the fittings with PTFE tape and final-fitted the HHO generators sandwiching them between neoprene foam, the pump is mounted and the plumbing is as complete as possible until the wiring is complete. Edited June 14, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Morpheus Posted June 14, 2012 Share Posted June 14, 2012 Thinking of having the text below or something similar engraved onto the top of the charge-cooler, does anyone have 'Supra' font? 2JZA80-GZE HHO H20/CH30H M-A343/0E A02B Eaton M112 Air-to-Water Charge-Cooled Designed & Built by David Payne The guys linked below should be able to help David, if no-one else can. I just found them, looking at a milling machine they're selling on eBay. They make a billet aluminium iPhone 4 case with custom engraving on the back and have the Supra logo on their GTE spark plug cover so might have the whole alphabet, (if it even exists). http://www.ebay.co.uk/itm/Toyota-supra-anodised-spark-plug-billet-engine-cover-/370574291873?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5647f2f3a1 Quote Link to comment Share on other sites More sharing options...
David P Posted June 15, 2012 Author Share Posted June 15, 2012 (edited) Thanks Morph, but in retrospect, I don't think Supra script would be the right choice. I started on the electrickery nest today and removed the w/m wiring I had previously installed for front pump fitting, but now the ERL pump has been moved to the rear. I had made a really 'good' job, it was all inside the OE loom sheathing which I had re-taped and cable tied akimbo, it took ages to retrieve it and I managed to fit the booster pump in-line before rain stopped play. There was one little inside job, persuading a T.T. cam belt cover to be N/A friendly, I was almost disappointed it only took 2 swipes of the angle grinder and a rub with the file. When fitting it I noticed the modified cam cover is leaking oil, it's weeping through the casting in several places, some nowhere near any welding, the casting is like a Wispa Bar and polishing it has broken the skin. The next time I work on the engine I will steam clean the inside and coat it with liquid metal. Edited June 16, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted June 15, 2012 Share Posted June 15, 2012 Looks fantastic, im really glad you stuck by this, im looking forward to a video of it screaming down the road! Quote Link to comment Share on other sites More sharing options...
David P Posted June 15, 2012 Author Share Posted June 15, 2012 (edited) Thank you. I'm looking forwards to a video of it screaming down the strip at Suprapod. Edited June 15, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted June 15, 2012 Author Share Posted June 15, 2012 (edited) I know you've seen it on youtube, but can't resist posting a still of it for the archives. Edited June 15, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted June 18, 2012 Author Share Posted June 18, 2012 I've been joining up some dots; the priming-pump is fitted and the wiring at the rear for the water/meth system and twin Pulse Width Modulators for the HHO generators is in. The tails are are coiled up in the woofer divot for now. Quote Link to comment Share on other sites More sharing options...
Morpheus Posted June 18, 2012 Share Posted June 18, 2012 Make sure you leave enough room for the flux capacitor Dave. Quote Link to comment Share on other sites More sharing options...
David P Posted June 21, 2012 Author Share Posted June 21, 2012 I thought Pulse Width Modulators were an upgrade? I have ordered the last few things on the list. Quote Link to comment Share on other sites More sharing options...
Noz Posted June 21, 2012 Share Posted June 21, 2012 Just watched the video of it running mate, looks the business. Maybe you should just run without a bonnet, save time! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 21, 2012 Share Posted June 21, 2012 Now David, what does 5 litres of water weigh? Right, 5 kilos. In a 5g accident what do you think those tie wraps are going to do about restraining a shock load of well over 25 kilos? What does it feel like to be struck with a fast moving 25 kilos on the back of the bonce? The "list" should have another line added.... Quote Link to comment Share on other sites More sharing options...
Noz Posted June 21, 2012 Share Posted June 21, 2012 Now David, what does 5 litres of water weigh? Right, 5 kilos. In a 5g accident what do you think those tie wraps are going to do about restraining a shock load of well over 25 kilos? What does it feel like to be struck with a fast moving 25 kilos on the back of the bonce? The "list" should have another line added.... That's where your wrong chris. He has used black super strong titanium weaved plastic carbon compound cable ties. I thought that was obvious Quote Link to comment Share on other sites More sharing options...
David P Posted June 21, 2012 Author Share Posted June 21, 2012 The bonnet is last on the list, so there might be a bit of that. I've been meaning to give that tank a better nailing down for some time, it's one of the few components that hasn't had to be moved. Quote Link to comment Share on other sites More sharing options...
Morpheus Posted June 21, 2012 Share Posted June 21, 2012 (edited) I thought Pulse Width Modulators were an upgrade? Oh yes, definitely but I found that it didn't help to produce more gas, just reduced the power consumption and heat build up in the water, which is still very important. You'll probably need to have them turned up fully to maybe equal direct connection output but you will certainly save amps and heat dramatically from just the high frequency on/off switching, which, like I said, produces as near as damnit the same gas output as without using PWM's atall. Yours are probably way better than my one though. My unit was made by a DIYer who copied the 'Stanley Meyer' circuit and built his own CNC mill to machine the extruded control box housings. All it does is vary amps, gate and frequency. Have you tested the system yet? You can get some fantastic explosions out of plastic bottles with the top third cut off and taped back on and the careful introduction of a fag lighter into the equation! By the way, I just found this video that I hadn't seen yet. Deals with PWM's for those who would like to know what they do. Related videos are in the right thumbnail list, of course and are well worth watching. 'It Runs On Water', in particular. Edited June 21, 2012 by Morpheus Added vid link. (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted June 22, 2012 Author Share Posted June 22, 2012 (edited) Waiting delivery of Potassium (KOH) and a pair of 30amp circuit breakers, but I could fuse the generators and run them without electrolyte. Next time I can get at it, it will be up and running. Not planning to use a water trap but haven't yet sorted out a flame trap? Looking forwards to games with it too. Edited June 28, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted June 22, 2012 Share Posted June 22, 2012 looking great mate Quote Link to comment Share on other sites More sharing options...
Morpheus Posted June 22, 2012 Share Posted June 22, 2012 Looking forwards to games with it too. Just make sure you wear welding gauntlets, full face protection and some decent ear defenders if you attempt to re-enact the Hindenburg's farewell landing with a two litre Coke bottle! Quote Link to comment Share on other sites More sharing options...
David P Posted June 22, 2012 Author Share Posted June 22, 2012 (edited) At long last, I have found an Engineer who can actually engineer. RJ Sutton Engineers, Nassington. He has re-cut the meeting faces of the adaptor and wheel, built up steel on the nose, then using a crank grinding machine has ground the journal in situ on the pump and pulley and it runs perfectly true. Within 24hrs of asking too. Thank you very much John. I will fit this pump/pulley/adaptor as a unit and have another made up for a spare. Edited June 24, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted June 28, 2012 Author Share Posted June 28, 2012 (edited) The pump with straight adaptor is fitted, nevertheless, now this component is functioning correctly, it has highlighted that the bracket is in need of an upgrade. I have been hoping to be ready enough to run this at Suprapod and Dan has told me if I could get it to him by Tuesday 3rd July and leave it with him, there's a slim chance Cinderella could get to the Ball. However, I can't get near the workshop until Monday 2nd, where there's more work than I can complete one day and the forecast is rain, rain and more rain, furthermore, if he couldn't find the time to set it up by the end of the week, it would then be 25th July before it could be done. I can't risk not having a car for a month. Edited July 3, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
