Pioneer 6x9 Speakers
Wez
Hey All,
I have this set of Pioneer 6x9 speakers up for grabs :thumbs:
Pioneers £20 delivered UK mainland
Pioneers
Some Installation info
I fitted 6x9's in the back of mine, i had to remove the whole rear internal quarter panel and the rear speaker bracket.Then made up a mdf fill panel 3/4 " thick that sits in the plastic panel where the speaker cover would normally sit(with no gaps so you get an air tight seal, i also used a thin foam back strip to help with the seal of the two panels), attach that by using screws from behind through the stock holes as not to damage your panel, but not too long so that they protrude through the mdf spacer.Then you can fit a 6x9 speaker to this as it gives you the depth you will require for the speaker & magnet.cover the lot then in a black acoustic cloth, hey presto it doesn't look to dissimilar to the stock look, but with a much better sound. I used 4 way speakers and didn't dynomatt the inner panel and i have to say it sounds pretty good.
But i do also have an active sub and and 3 way 6.5 in the front on the mdf brackets.
Maybe i should knock up a batch and do a group buy;-)
  • 3 weeks later...
  • 7 months later...
  • 2 months later...
  • 1 month later...
  • 3 weeks later...
  • 5 weeks later...
  • 3 months later...
  • 2 weeks later...
