Chris Wilson Posted November 17, 2010 Share Posted November 17, 2010 I have an elderly Compaq Evo N600C laotop I use for mapping and car diagnostics because it has a proper serial port. It only has a small hard drive in it and it's nearly full. I want to keep it and fit a bigger drive. The HP site gives the following storage specs: Storage Diskette Drives Optional Diskette Drive Optical Drives DVD/CD-RW Combo Drive CD-RW Drive or DVD-ROM Drive or CD-ROM Drive Hard Drives One of the following: 40-GB SMART Hard Drive 30-GB SMART Hard Drive 20-GB SMART Hard Drive What sort of size drive can I get for it? I assume it's not a SATA drive, but what is it I need to look for? Just an ATA drive? What's a SMART drive? Where's the best place to buy one? Anyone here selling one? Thanks Quote Link to comment Share on other sites More sharing options...
comorin219 Posted November 17, 2010 Share Posted November 17, 2010 could,nt you just get an external one then you could have 100's of GB ( just a thought) Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted November 17, 2010 Share Posted November 17, 2010 Hi Chris It's a ATA drive. ATA-5 to be specific. You should be able to use any ATA drive available in 2.5" size. Lots of info here: http://h18000.www1.hp.com/products/quickspecs/10886_div/10886_div.HTML I would choose as large a drive that fits the physical parameters of the largest of the drives in that link. But you should easily be able to get a cheap 100+gb drive in there. Trouble is; do you want the installed OS, applications and data to remain intact or would you be able to do a re-install? If you would keep the data on the drive, you should look into getting a 2.5" external box for the new drive and then use a disc clone util to copy everything over. The box itself shouldn't be more that 20£ or so If you can reinstall, that would be best as you will have a faster computer Alternatively just get a small external USB drive and and use that for all data and keep OS and apps on the system drive. However, as far as I can find, the computer only supports USB 1.1 which makes such an USB drive really really slow to use. Also, the cloneing mentioned above WILL take a loooong time, but that should be ok as it's only needed to be done that one time. /Stefan Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 17, 2010 Author Share Posted November 17, 2010 I have an external drive but it's a nuisance when working on cars with it flailing about, would like to fit a bigger internal one, but thanks for the suggestion. I will use the external one to Ghost the hard drive image. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 17, 2010 Author Share Posted November 17, 2010 Would this do: http://cgi.ebay.co.uk/WD-2-5-SERIAL-ATA-HARD-DRIVE-250GB-WD2500BEVT-OEM-/110612944698?pt=UK_Computing_HardDrives_RL&hash=item19c10b973a Thanks! Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted November 17, 2010 Share Posted November 17, 2010 Good idea using you existing drive to ghost the disk. I would go for something like THIS as a new drive. According to the link I posted before, that should fit nicely in the "mulitbay drive adaptor". And its chep @ 35£ or so.. EDIT: The one you suggested is Serial ATA. You need ATA (also called Parallel ATA) according to the link above. I also did a search that supported the fact that the computer is ATA and not S-ATA. You can check yourself by getting the drive out and checking the interface. ATA is like 30 little pins and S-ATA is more of a flat plastic connector with connection points on it. Also, the drive itself should say on the sticker. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 17, 2010 Author Share Posted November 17, 2010 OK, bought one of those new off Ebay for £34.99 thanks!! It is ATA, didn't realise getting at it was so easy. Glad I asked, could easily have bought that SATA by mistake... Quote Link to comment Share on other sites More sharing options...
