Brakes making a creaking noise at low speeds
TonytotheB
Hey chaps
My UK spec brakes have started making a weird creaking sound - almost like a clunk. I have been dreading asking what the problems is because I get the feeling it will shock me but here goes: what could this be? Do I need new pads? Should I check brake fluid?
I am asking my good buddy Wilo-I have a Porsche-Orange to help me out
They are 4pot front and 2 pot back. I cannot isolate where the sound is coming from.
Huuuuuuuuuuuuuuge thanks in advance
Teebs
  • 5 weeks later...
Mine 's doing the same
i guess this is due to the pads starting to be "mirrored" (i'm french so...:) )
i think scratching the pads would help
Its called de glazing :) use some 80 grit wet and dry paper and hold it on a flat surface then rub the pad over it, do the same to the discs.
