mellonman Posted November 16, 2010 Share Posted November 16, 2010 All just wondering when you would replace the water pump, or how would you know if it was failing.i see alot of people have changed theres so was just wondering do they detireate with age? Link to comment Share on other sites More sharing options...
Dnk Posted November 16, 2010 Share Posted November 16, 2010 As far as i know mine was fine but decided to fit a new one when i had a chunk of other work done, valve stem seals, cam belt, belt pulleys and tensioners, ac rad. 16 yrs old and 130,000 miles, the cars always been run on Cool Red though so that might make a differance Link to comment Share on other sites More sharing options...
Swampy442 Posted November 16, 2010 Share Posted November 16, 2010 When you do the cambelt is logical as its exposed, so 60k miles/100k kms but Im not sure its lifed as such Link to comment Share on other sites More sharing options...
mellonman Posted November 16, 2010 Author Share Posted November 16, 2010 Yeah i see your point, but is there signs of fail before its to late like would it start to over heat slightly things like that, Link to comment Share on other sites More sharing options...
bignum Posted November 16, 2010 Share Posted November 16, 2010 Either, 1. when it starts to leak(normally from the front bearing and onto the alternator, which mine did) 2. when the bearing starts to make a whining noise, normally when 1st starting the car, 3. if you are replacing the cambelt anyway, as you`re at the w/pump and if the pump hasn`t been done it makes sense to replace it now, Erm thats it really. Link to comment Share on other sites More sharing options...
mellonman Posted November 16, 2010 Author Share Posted November 16, 2010 bignum simptoms love it helps everyone 2.makes a whining noise when starting when first starting! this is exactly why i asked this question as mine seemed very load this morning almost like it had a super charger like from mad max lol, but wasnt sure if it was down to it beeing icy Link to comment Share on other sites More sharing options...
jackso11 Posted November 16, 2010 Share Posted November 16, 2010 Could also be you pas pump Link to comment Share on other sites More sharing options...
Shane Posted November 16, 2010 Share Posted November 16, 2010 Mellonman's is a TT I think, but if it were an NA, I would say it is pointless changing the pump without changing the 20mm core plug inthe rear pump housing as well once it was all out and exposed. Not had the TT one out, but dont think the TT one has the same core plug. Link to comment Share on other sites More sharing options...
mellonman Posted November 16, 2010 Author Share Posted November 16, 2010 yeah mine is a tt jspec i have had look on ebay and there are some different types they say they fit but gasgets look different so does anyone know if uk and jspec are different? Link to comment Share on other sites More sharing options...
stevie_b Posted November 16, 2010 Share Posted November 16, 2010 When you do the cambelt is logical as its exposed, so 60k miles/100k kms but Im not sure its lifed as such 3. if you are replacing the cambelt anyway, as you`re at the w/pump and if the pump hasn`t been done it makes sense to replace it now I was under the impression the water pump on the Supra isn't driven by the cambelt, but I might be wrong. 2.makes a whining noise when starting when first starting! this is exactly why i asked this question as mine seemed very load this morning almost like it had a super charger like from mad max lol, but wasnt sure if it was down to it beeing icy This could potentially be any of the pulleys. The aux belt tensioner pulley gets noisy with age (although doesn't really sound like a supercharger, more like just a squeal). Link to comment Share on other sites More sharing options...
Shane Posted November 16, 2010 Share Posted November 16, 2010 (edited) It's driven by the auxilary belt,but the cambelt needs to come off to be able to remove the pump. There are different part Numbers for the TT and NA, but side by side they look identical, at least the after market ones I ordered in did. I have a feeling the numbers may be different due to the different rear pump housing used between models, but if you are replacing just the main pump then I dont think there will be an issue. Edited November 16, 2010 by Shane (see edit history) Link to comment Share on other sites More sharing options...
Nic Posted November 16, 2010 Share Posted November 16, 2010 yeah mine is a tt jspec i have had look on ebay and there are some different types they say they fit but gasgets look different so does anyone know if uk and jspec are different? Part number J-spec 16100-49846 Toyota Water Pump Link to comment Share on other sites More sharing options...
mellonman Posted November 16, 2010 Author Share Posted November 16, 2010 Part number J-spec 16100-49846 Toyota Water Pump super nic with part numbers what price can you do one for nic Link to comment Share on other sites More sharing options...
mellonman Posted November 16, 2010 Author Share Posted November 16, 2010 but are uk and jspec different? Link to comment Share on other sites More sharing options...
Nic Posted November 16, 2010 Share Posted November 16, 2010 super nic with part numbers what price can you do one for nic Sorry I'm not trading at the moment. Not sure if the UK spec is the same, haven't got the EPC on this machine to be able to check. Link to comment Share on other sites More sharing options...
mellonman Posted November 16, 2010 Author Share Posted November 16, 2010 no worries nic thanks for the help Link to comment Share on other sites More sharing options...
mellonman Posted November 16, 2010 Author Share Posted November 16, 2010 this does look like the one but are these cheaps ones any good? http://cgi.ebay.co.uk/TOYOTA-SUPRA-3-0i-TT-JZA80-2JZ-GTE-93-02-WATER-PUMP-NEW-/180482020834?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a059115e2 Link to comment Share on other sites More sharing options...
