Selecting the correct size wastegate
Wez
Hey All,
I am trying to decide which size wastegate to go for, the turbo is likely to be a BW unit which will be bolted onto an Arnout cast manifold. I have just measured the manifold wastegate port and its 50mm.
Looking at the Tial range of wastegates there are a number of options ranging from 38mm up to 60mm with vband fitment.
MVS - 38mm
MVR - 44mm (replacement for V44)
V60 - 60mm
With my modest power level I am thinking the 38mm MVS may be sufficient, what are peoples thoughts?
http://www.tialsport.com/prod_wg.htm
  • 1 month later...
The point of wastegates is to divert gas around the turbine,
thus reducing the power transferred to the compressor. The key to good
wastegate control is proper sizing and calibration. Just slapping on a
wastegate with the "X psi" spring is a recipe for failure. If you're
doing a proper match (granted that's hard without turbine maps that show
shaft RPM), then you can compute the percentage of the exhaust flow that
has to be diverted around the turbine. From there you have to estimate a
discharge coefficient of the wastegate (at various openings) to
determine how much opening is required. A correctly sized wastegate will
have sufficient high end flow as well as good movement resolution. If
you're seeing a lot of boost creep, you either need to go to a larger
A/R or a larger wastegate. The problem with an oversized wastegate is
that it can dump too aggressively at lower amounts of travel. The
turbine may then not be able to power the compressor at higher flows
and/or boost levels, and you'll see the torque drop off. Logged data of
wastegate travel is a huge help in determining proper wastegate sizing
and control. Proper wastegate control is key to making a good,
engineered powerband.
If you don't log something, you're just guessing! DATA is the key!
