fruity_south Posted November 14, 2010 Share Posted November 14, 2010 Quick question for you all. just to clear up any confusion in my head. Some of this will come across as obvious to some but just want to check. The soarer has a Radiator, auto box cooler built into the radiator, air con rad thing, power steering cooler, oil cooler for the fan oil system and one for the engine oil. is this right? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 14, 2010 Share Posted November 14, 2010 Correct apart from the engine oil cooler. Im not 100% sure theres a fan cooler either Quote Link to comment Share on other sites More sharing options...
fruity_south Posted November 14, 2010 Author Share Posted November 14, 2010 there is a fan cooler as i removed the system, the fan had its own oil system, i guess to keep it running smoothly, and it ran to a lil cooler, well from what i can remember it did. so the engine it self doesnt have a cooler for the engine oil? there seems to be a lot of oil lines that come out of the engine, jst wish i took pictures of them all first. Quote Link to comment Share on other sites More sharing options...
Andy-No-Knee Posted November 14, 2010 Share Posted November 14, 2010 Which V8 Soarer is it? The reason is if it is a UZZ32 Active then the power steering has a larger cooler as well (it has 4 wheel steering) The others will have Air con rad Water rad with auto box cooler built in Small power steering cooler (basically 2 foot of tube in the near side duct). Not sure about a cooler for the fan, it depends on the model. Quote Link to comment Share on other sites More sharing options...
fruity_south Posted November 14, 2010 Author Share Posted November 14, 2010 thats right i had a rad with autobox buit in, the pipes for the powersteering cooler and i had one little cooler in the passenger front air scoop. this is what i thought was connected to the hydrulic fan system. just i want to replace all the little coolers with a mocal cooler when i fit it to the supra. i have already replaced the rad and auto box cooler. so i need one for the power steering, i could o sworn the soarer had one come off the engine for the engine oil. Quote Link to comment Share on other sites More sharing options...
