Headlights working, but not rear driving lights
AndrewOW
As standard, all the sidelights and the front fog lights work from one fuse in the footwell. I had a problem with the front fog light relay recently which also resulted in the loss of all the sidelights.
That's interesting, as the fog light switch was on, but no fog lamps either (they are all wired into the rear lights cluster). One front sidelight is working, but it's been a gradual loss of the others as maybe the bad earth, or wiring has corroded enough for it to cause a short or something. :)
Is the interior dash light working?
I had a similar issue which was down to a relay problem.
The rear tail-lights, and interior dash lights wouldn't work though.
All the dashlights work, and one front sidelight working. It's a tad odd.
Well, I have now found out that it's the bulb failure warning module that's burnt out because of bad wiring from the installation of the facelift sidelights/indicators, etc, which is going to set me back about £300 including fitting!
I also found this very old thread that also mentions the problem I've got.
http://www.mkivsupra.net/vbb/showthread.php?6576-Poxy-Lights.!!!!!&highlight=bulb+failure+module
Two days off the road too, unfortunately. :(
Edited by AndrewOW (see edit history)
