Baz018 Posted November 13, 2010 Share Posted November 13, 2010 Hi, when i start the supra from cold it keeps stalling inless i put a few revs on for about 30sec then after that it will tick over fine. It will also be fine the rest of the day its just when it not been used for a few days. Any ideas why it wont start properly?? Link to comment Share on other sites More sharing options...
ADD Posted November 13, 2010 Share Posted November 13, 2010 have you noticed any blue smoke on start up? if so stem seals may be leaking, therefor not allowing car to start very well or hesitate when starting. Link to comment Share on other sites More sharing options...
edge Posted November 13, 2010 Share Posted November 13, 2010 Make sure your battery is nice and healthy too. Link to comment Share on other sites More sharing options...
Nic Posted November 13, 2010 Share Posted November 13, 2010 NA or TT? Link to comment Share on other sites More sharing options...
Josh Posted November 13, 2010 Share Posted November 13, 2010 na or tt? It's a TT. Link to comment Share on other sites More sharing options...
Baz018 Posted November 13, 2010 Author Share Posted November 13, 2010 Yeah its a tt. Battery is fairly new to. Ill have a look for the blue smoke 2moz where abouts and what are the stem seals? Link to comment Share on other sites More sharing options...
Dnk Posted November 13, 2010 Share Posted November 13, 2010 Stem seals are on the valve stems, when their shot they let oil run into the combustion chamber and you get smoke on start up. Mine were totally scrap and didnt affect how the car started though. Link to comment Share on other sites More sharing options...
Nic Posted November 13, 2010 Share Posted November 13, 2010 (edited) Has it only just started doing it, anything you can think of that you've done that may have caused the problem ie. any changes made to the car, fill up with different fuel to normal etc? few suggestions Idle control valve sticking. Bad earth Battery terminals clean/tight. When was the oxygen sensor last changed? Try resetting the ECU (disconnect the battery for a few minutes) it'll run rough to start with and will take a few miles run right again, see if it makes a difference. When were the plugs last changed? Check for any pipes in engine bay that may have popped off. Edited November 13, 2010 by Nic (see edit history) Link to comment Share on other sites More sharing options...
