Heater matrix plumbing
johnd-mkiv
Im looking at puting a small heater in my car as cant be doing with the front screen misting all the time, I have 3 ports on the engine that are blocked
one from the back of the water pump
one off the back of the head
one around the oil filter
which two of these will be my flow an return as for the life of me cant remeber the plumbing, im guessing the back of the water pump will be the flow.
John
The one on the back of the pump is the return, it's the line is the front most one which goes over the top of the cams and down the exhaust side of the engine. The one from the back of the block should be the feed to the matrix.
Edit, just checked and confirmed. Quick pic form the service manual, hope this helps
