Billet timing tensioner bracket (mkiv)
Guest supra_phreak
I would definately fit one on any big power Supra after what happened to my engine. I can arrange a group buy if there is enough interest?
Like Paul says if you are looking for big power you cannot take any chances and they are a nice insurance policy, the yanks seem to have had a few fail so I would say if Paul can arange a group buy that would be cool, we will prob be up for a couple as we have a couple of big builds going on soon, Paul also sells the Gates racing timing belt which if you are buying these is really a must, so maybe Paul you can do a price with the Gates belt. From memory they do not come with a pulley on so the bearing in the pulley is available from any bearing shop, that should take care of the tensioner side of things.
Guest supra_phreak
I found a guy on supra forums selling them (titan brand) for 150 shipped! He said he has multiple. Great buy!!! :) User is flatline16 over there if you guys want to get in on it.
I'm interested as to why people think these have broken in the past?
The cam belt doesn't see any increase in load as power increases. The only load it should see is the load required to turn the camshafts, which would only increase if particularly aggressive cams or valve springs were used.
The worst case scenario for the belt is WOT revving the engine in neutral then lifting off fully.
Other than that I can't see why they'd break.
Still belts and braces and all....
  • 2 years later...
