sports brakes for the n/a
Guest supragirl
Guest supragirl
ive got a 1993 mk4 auto n/a and my brakes are getting abit worn, does anyone know where i can get some sports discs and pads alround as i cant seem to find and, or could i put the tt brakes on it as ive found some for that. any help would be apreciated
You can fit the UK spec brakes. it's very popular but not particularly cheap.
If you want to keep your existing setup you can fit some fast road pads, available from Chris Wilson (on here). :)
The UK car which is a TT came with the bigger brakes.
The import TT came with the smaller brakes or the bigger brakes (UK spec)
The stock brakes on the NA are adequate for its performance, but if you want slightly better braking go for Chris Wilson's brake pads. THe UK brakes will ofcourse be the best option in terms of braking but they will cost u about 800quid for the whole setup. But if u feel like busting the cash, go for it!!!
cheers
