Adding Fuses to Fuse Box
Sandy-m2
hi sandy
n/stk terminal repair t82998-12140 they was £2.93 each +vat in 2008 remember you need 2 per fuse.
Each terminal comes with about 6inch's of wire attach and they push in from the bottom of the fuse board.There is a locking pin that pulls out from the top of the fuse board that needs to be pulled before you fit the terminal,then replaced once terminal is fitted
hth simon
Very interesting, I didn't know you could do this. This will neaten up my airhorn compressor fuse.
Rob, if you have a few of these could I have a couple of terminals please (enough to fit 1 additional fuse)? Do yours have the wires attached or would I need to crimp that on myself?
Many thanks.
