Is Window Tint Removal a Professional or DIY Job?
dandan
Hi guys,
I'm giving some thought to buying this Ford Focus but I don't like the dark front tints and would need to have them removed. Can it be done easily or do I need to take it to a "tinting shop" :D to have it untinted?
Cheers
Dan
[ATTACH=CONFIG]122761[/ATTACH]
I removed a dark tint from my supra's rear window: fairly easy to do, just get it warm and peel it back slowly and steadily. Can leave a sticky residue behind, but that can be cleaned off with various cleaning products (search on here for info). For windows without heated elements, you can probably go nuts a bit more with the cleaning.
if its not been on there long , it will peel of quite easily , may leave some glue , but glue/tar remover will sort that out .
now if its been on a while it could be a sod to get off , your going to have to get a heat gun / hairdryer , pick an edge and work it very slowley or it will come off in bits , same as before glue and tar remover then clean the glass
