Suprab1 Posted November 8, 2010 Share Posted November 8, 2010 Has anyone fitted evo brembo calipers onto there supra? I've just been looking at the price of these & for evo 8 & 9 calipers you can get them for under £400 including pads, clips & all else. What would be needed to make them? Would they be a good upgrade? Quote Link to comment Share on other sites More sharing options...
dude Posted November 8, 2010 Share Posted November 8, 2010 They do come in 2 sizes, the larger would definatly be nice, I would imagine its just a case of making some mounting brackets. We have an EVO coming in with no brakes and he is thinking of the stock large Brembo's, I could have a little 'offer' up if we have time. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted November 8, 2010 Share Posted November 8, 2010 They do come in 2 sizes, the larger would definatly be nice, I would imagine its just a case of making some mounting brackets. We have an EVO coming in with no brakes and he is thinking of the stock large Brembo's, I could have a little 'offer' up if we have time. If you made up brackets to sell on I reckon you'd sell loads. Quote Link to comment Share on other sites More sharing options...
dude Posted November 8, 2010 Share Posted November 8, 2010 They are prob the same as my AP brackets, we made a few over at the old shop but we had a mill there. Quote Link to comment Share on other sites More sharing options...
Scott Posted November 8, 2010 Share Posted November 8, 2010 Do the brembos come with bracket kits anyway? In other words, are the calipers themselves all the same with fitting kits for each car model? Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted November 8, 2010 Author Share Posted November 8, 2010 They do come in 2 sizes, the larger would definatly be nice, I would imagine its just a case of making some mounting brackets. We have an EVO coming in with no brakes and he is thinking of the stock large Brembo's, I could have a little 'offer' up if we have time. What do you mean they come in 2 sizes? Do you mean later evos have bigger brakes? I know the fq400 has the big alcons but i thought the 7,8 & 9 were all 4 pot front 2 pot rears? Would these mounting brackets be expensive to get made up? Sorry for all the questions, i'm just trying to work out if there would be much price difference between doing this or just buying something like ksports. Quote Link to comment Share on other sites More sharing options...
Homer Posted November 8, 2010 Share Posted November 8, 2010 Without knowing the full specs on the brakes it'd be wrong to speculate if it's a good choice for the supra. Take a look here and input the Evo specs: http://www.mkivsupra.net/vbb/showthread.php?225007-Big-Brake-Kits-Real-Numbers Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted November 8, 2010 Author Share Posted November 8, 2010 Without knowing the full specs on the brakes it'd be wrong to speculate if it's a good choice for the supra. Take a look here and input the Evo specs: http://www.mkivsupra.net/vbb/showthread.php?225007-Big-Brake-Kits-Real-Numbers I had a look at that, but to be honest don't really understand it lol. The evo brembos would surely be better than my jspecs? The 996 Turbo seems to be something like the evo (4 pot 330mm). Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted November 8, 2010 Author Share Posted November 8, 2010 Do the brembos come with bracket kits anyway? In other words, are the calipers themselves all the same with fitting kits for each car model? I would think you are right but don't know. It would make sense to do this. Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted November 9, 2010 Share Posted November 9, 2010 Drop Stratty (Simon) a PM, he has got Evo VIII Brembo's on his car, he will be able to help you. Quote Link to comment Share on other sites More sharing options...
dcarrter21 Posted November 9, 2010 Share Posted November 9, 2010 My old rangerover sport ones fitted nicely! Worked really well as they were designed to stop a 2.5 odd tonne 4x4. I would be carefull with your choice and research it well! If your getting the calipers off other cars custom brackets will be needed Quote Link to comment Share on other sites More sharing options...
dandan Posted November 9, 2010 Share Posted November 9, 2010 They may not be better than your Jap spec brakes and they may not have anything like the correct front to rear bias either. If you find out the caliper's piston diameters, the pad height (radial measurement - probably something like 50-60mm) and the disc diameter I can tell you how they'd compare and what the bias change would be. I could do with some Jap spec brake info as well and then I can add that in to the comparison. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted November 9, 2010 Share Posted November 9, 2010 Does this Help Dan PRODUCT MODEL Mitsubishi Lancer Evolution 5 6 CP9A With 320mm Disc's (Brembo Caliper Models) - EVO 5 & 6 Description 1 Complete Set Of Standard Replacement Front Brake Disc's And Standard Front Brake Pad's To Fit A Mitsubishi Lancer Evolution 5 & 6 Fitted With 320mm Front Brake Discs And Brembo Calipers. - EVO 5 & 6 - CP9A Quantity 2 X Standard Front Replacement Brake Disc's. 1 X Complete Set Of Standard Front Brake Pads. (4pads) Model Mitsubishi Lancer Evolution 5 - EVO 5 Mitsubishi Lancer Evolution 6- EVO 6 Chassis No. CP9A Diameter (mm) 320mm Height (mm) 43.5mm Brake Disc Type Vented Thickness (mm) 32mm Minimal Thickness (mm) 29.8mm Number Of Holes 5+2 OE Part No. Equivalent BRAKEKIT007Disc's = MR370723 Pad's = MR407376 Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted November 9, 2010 Author Share Posted November 9, 2010 They may not be better than your Jap spec brakes and they may not have anything like the correct front to rear bias either. If you find out the caliper's piston diameters, the pad height (radial measurement - probably something like 50-60mm) and the disc diameter I can tell you how they'd compare and what the bias change would be. I could do with some Jap spec brake info as well and then I can add that in to the comparison. I'm on it Drop Stratty (Simon) a PM, he has got Evo VIII Brembo's on his car, he will be able to help you. Will do, thanks mate. Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted November 9, 2010 Author Share Posted November 9, 2010 They may not be better than your Jap spec brakes and they may not have anything like the correct front to rear bias either. If you find out the caliper's piston diameters, the pad height (radial measurement - probably something like 50-60mm) and the disc diameter I can tell you how they'd compare and what the bias change would be. I could do with some Jap spec brake info as well and then I can add that in to the comparison. Is this what you need? Front caliper Piston sizes are: 46mm & 40mm Front disc diameter is 320mm Front Pad Radial swept depth is 60mm Rear Piston sizes are: 40mm & 36mm Rear Disc diameter is: 300mm Rear Pad Radial swept depth is: 46mm if i remember right but will have to double check tomorrow if required. Quote Link to comment Share on other sites More sharing options...
