HDMI leads???
peter richards
A quote from the Which Magazine
When Which? lab tested the following HDMI leads, the cheapest lead proved just as good as the most expensive:
A £10 Tesco Value HDMI lead
A £20 John Lewis HDMI lead
A £100 Belkin HDMI lead
Amazingly, our expert viewers saw no difference at all in the picture quality when using the three HDMI leads, with our technical tests confirming identical performances. We passed data through all our HDMI leads at 6.2Gb per second – a data rate more demanding than Blu-ray – without a single error occurring.
The simple rule here is to save your money and buy the cheapest available. All HMDI leads have gold plated connecting pins and Which? testing has shown that you will not see any data loss even when using the cheapest leads.
The most expensive HDMI leads could cost the same as your new Blu ray player, but it is totally unnecessary to spend that much.
O/T a little, but if you are looking into HDMI for venues you can send HDMI signals over Cat5 (for distance) check it out, http://www.cabletime.com/products/mediastar-evolution/ (Mediastar Evolution HD)
We use it onboard the boat im working on and its class :)
Thanks for the link.
We run VGA and S-vid over cat5 quite some times, cant beat a direct connection with VGA and video for reliability so we try and stick to that, but always use active input plates to ensure that any laptop that comes in will work. Not all laptops run the same power output in the VGA port so we build it to work with all.
Have not had any call to use HDMI in any of the venues but it now comes as standard on the NEC NP905 and NEC NP3250 projectors so we may as well start building it in to the default spec.
