EMPEROR Posted February 5, 2011 Share Posted February 5, 2011 At least can anyone tell me what's the greyish plug next to the igniter for? And what color wire goes into it? Link to comment Share on other sites More sharing options...
Andy Blyth Posted February 5, 2011 Author Share Posted February 5, 2011 EMPEROR said: At least can anyone tell me what's the greyish plug next to the igniter for? And what color wire goes into it? That's for the condensor / capacitor. It supresses electrical interference from the ignition system. It connects to +12v ignition and ground so the wires will be black-orange and brown. I'm not sure if the colours are the same on a VVTI. Link to comment Share on other sites More sharing options...
EMPEROR Posted February 5, 2011 Share Posted February 5, 2011 (edited) Andy Blyth thanks mate, So this is a two wire plug? I have two wires left... one is black-white (which is coils GND) and one brown (GND same as igniter's GND). Could these two be the wires for this plug? I found this: http://i224.photobucket.com/albums/dd108/wilbo666/final35.jpg But unfortunately I don't have the previous page and I can't see where a), b) and c) are going... Edited February 5, 2011 by EMPEROR (see edit history) Link to comment Share on other sites More sharing options...
Andy Blyth Posted February 5, 2011 Author Share Posted February 5, 2011 On your diagram the 12V ignition (rather than gnd) is black-white so they could be the wires you are looking for. This seems to be a difference between the VVTI and non-VVTI. I expect that the condensor will appear on the schematic for the radio, rather than the ignition, based on its location in the parts catalogue. Link to comment Share on other sites More sharing options...
EMPEROR Posted February 5, 2011 Share Posted February 5, 2011 Thank you mate! You were really helpful! Now I just need to find upper fusebox connector wiring (for the VVTi) and I'm done! Hate how some people cut wiring wherever it pleases them... instead of just unplugging the connectors Link to comment Share on other sites More sharing options...
Andy Blyth Posted February 5, 2011 Author Share Posted February 5, 2011 EMPEROR said: Now I just need to find upper fusebox connector wiring (for the VVTi) and I'm done! If you have the mating half connector mounted on the fusebox to study, can you match the wires on the engine harness by colour? Link to comment Share on other sites More sharing options...
EMPEROR Posted February 5, 2011 Share Posted February 5, 2011 I guess so, but then again depends on the color scheme for non-vvti and vvti engines. Hopefully they are the same though. The problem is that my SZR has plug with 3 pins, and as far as I remember they should be 5 pins. I saw the upper fusebox connector on the first page and found pins 1, 4 and 5. They are the same color. I have two more wires: - black-white wire which is coming from C1 ( http://i224.photobucket.com/albums/dd108/wilbo666/final314.jpg ) - blue-red coming from C7 (I am not sure if this is not pin 5 on lower fusebox connector) Since traction is integrated in the ECU there are lots of differences on this wiring harness... Link to comment Share on other sites More sharing options...
EMPEROR Posted February 8, 2011 Share Posted February 8, 2011 (edited) Here are the VVTi fusebox connectors guys... I finally beat them to the ground : UPPER FUSEBOX CONNECTOR: No code has to be inserted here. 1 wire with different color on the upper fusebox connector (pin 3) LOWER FUSEBOX CONNECTOR: No code has to be inserted here. 2 wires less and 2 with different color on the lower fusebox connector (pin 4 and pin 8) ECU pins C1, C7, C8, C10, C16 and G13 are taken from here: http://i224.photobucket.com/albums/dd108/wilbo666/final314.jpg http://i224.photobucket.com/albums/dd108/wilbo666/final315.jpg Edited February 9, 2011 by EMPEROR (see edit history) Link to comment Share on other sites More sharing options...
EMPEROR Posted February 19, 2011 Share Posted February 19, 2011 (edited) VVTI TT ORANGE FOOTWELL CONNECTOR: No code has to be inserted here. Edited January 10, 2012 by EMPEROR (see edit history) Link to comment Share on other sites More sharing options...
EMPEROR Posted February 19, 2011 Share Posted February 19, 2011 (edited) VVTI TT GREY FOOTWELL CONNECTOR (ENGINE WIRING): No code has to be inserted here. VVTI TT GREY FOOTWELL CONNECTOR (UNDER DASHBOARD FIREWALL WIRING): No code has to be inserted here. Edited May 7, 2012 by EMPEROR (see edit history) Link to comment Share on other sites More sharing options...
EMPEROR Posted February 19, 2011 Share Posted February 19, 2011 (edited) VVTI TT WHITE FOOTWELL CONNECTOR (ENGINE WIRING): No code has to be inserted here. * - for Tiptronic Gearbox VVTI TT WHITE FOOTWELL CONNECTOR (UNDER DASHBOARD FIREWALL WIRING): No code has to be inserted here. * - for Tiptronic Gearbox Edited May 7, 2012 by EMPEROR (see edit history) Link to comment Share on other sites More sharing options...
Konrad Posted May 23, 2011 Share Posted May 23, 2011 Andy, could you fill up gaps for Auto guys on orange plug? Pin 7 - P, Pin 36 - R, Pin 1 - N, Pin 18 - D, Pin 17 - 2, Pin 27 - L Link to comment Share on other sites More sharing options...
Guest SupraDoper Posted July 15, 2011 Share Posted July 15, 2011 (edited) Solid VVTi connector guide. Completed a custom aristo vvti to supra spec engine harness conversion with the above, for a twin turbo swap. Started first turn. Everything works. No traction control as I didn't wire it up. Thanks Edited July 15, 2011 by SupraDoper (see edit history) Link to comment Share on other sites More sharing options...
leesupra12 Posted September 4, 2011 Share Posted September 4, 2011 hi have you anychance got the 1jzgte non vvti auto footwell connectors. thanks lee Link to comment Share on other sites More sharing options...
Andy Blyth Posted September 4, 2011 Author Share Posted September 4, 2011 I'm afraid not, Lee Link to comment Share on other sites More sharing options...
EMPEROR Posted December 30, 2011 Share Posted December 30, 2011 (edited) VVTI TT THROTTLE VALVE MOTOR No code has to be inserted here. VVTI TT ACCELERATION SENSOR No code has to be inserted here. VVTI TT THROTTLE POSITION SENSOR No code has to be inserted here. Some more connectors while I was investigating why my DBW is not working... This I have to check for sure - VTA/VTA2: 0.3-0.8V with the ignition switch on and the throttle valve fully closed 3.2-4.9V with the ignition switch on and the throttle valve fully open Edited January 23, 2012 by EMPEROR (see edit history) Link to comment Share on other sites More sharing options...
EMPEROR Posted January 22, 2012 Share Posted January 22, 2012 (edited) FACELIFT ABS ECU (89541-14060) - SZ, SZR, RZS - (* W/ TRACTION) A No code has to be inserted here. B No code has to be inserted here. FACELIFT ABS ECU (89541-14070) - RZ US Spec A No code has to be inserted here. B No code has to be inserted here. Edited May 7, 2012 by EMPEROR (see edit history) Link to comment Share on other sites More sharing options...
EMPEROR Posted January 22, 2012 Share Posted January 22, 2012 (edited) FACELIFT ABS Actuator (44510‑14090) - - SZ, SZR, RZS A No code has to be inserted here. B No code has to be inserted here. FACELIFT ABS Actuator (44510‑14100) - RZ A No code has to be inserted here. B No code has to be inserted here. Edited April 22, 2012 by EMPEROR (see edit history) Link to comment Share on other sites More sharing options...
EMPEROR Posted January 22, 2012 Share Posted January 22, 2012 (edited) FACELIFT ABS Relay (88263‑35090) - SZ, SZR A No code has to be inserted here. B No code has to be inserted here. FACELIFT ABS Relays - RZS, RZ ABS Motor Relay (88263‑24020) No code has to be inserted here. ABS Solenoid Relay (88263‑24030) No code has to be inserted here. Edited December 29, 2013 by EMPEROR (see edit history) Link to comment Share on other sites More sharing options...
EMPEROR Posted January 22, 2012 Share Posted January 22, 2012 (edited) FACELIFT Deceleration Sensor (89441‑20050) - RZ No code has to be inserted here. Edited May 8, 2012 by EMPEROR (see edit history) Link to comment Share on other sites More sharing options...
EMPEROR Posted May 8, 2012 Share Posted May 8, 2012 (edited) VVTI TT IGNITER No code has to be inserted here. I got all the wiring out of 98 RZ, so might take all connectors pinout if anyone is interested. Still can't figure why some wires are going dead end... Meanwhile I am updating the older posts too. Edited May 16, 2012 by EMPEROR (see edit history) Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 8, 2012 Share Posted May 8, 2012 Surely pin 9 goes to a switched ignition positive feed? Link to comment Share on other sites More sharing options...
Ian C Posted May 8, 2012 Share Posted May 8, 2012 +B is battery feed, i.e. a constant power source even with the ignition off, used for ECU memory keepalaive and radio memory. Link to comment Share on other sites More sharing options...
EMPEROR Posted May 8, 2012 Share Posted May 8, 2012 (edited) Yes, my mistake, thanks! Chris is correct, it goes to switched ignition positive feed Glad there are ppl who are actually looking at this thread P.S. I knew I checked this... It's on the previous page - 12V Ignition (Grey Footwell Connector Pin1) Edited May 8, 2012 by EMPEROR (see edit history) Link to comment Share on other sites More sharing options...
JohnW Posted March 17, 2013 Share Posted March 17, 2013 I found a Toyota Wire Harness Repair Manual (1991-2005), document no. RM1022E. It has information on electrical connectors and terminals. A PDF version was found on the internet. Another forum posted information that most of the connectors were supplied by Sumitomo from the TS series. The connectors I have researched are either type 1.3 or 2.3 II. Not too many sources for these connectors have been found. The most promising is http://www.amayama.com. With this site a material list is created and submitted for quotation. Link to comment Share on other sites More sharing options...
