Davey001 Posted November 7, 2010 Share Posted November 7, 2010 Hey all, I'm enjoying every bit of my turbo conversion apart from when the intercooler couplers warm up a bit they pop off or the pipe is blown out. I know I should have had a bead welded around the pipes but just wondered if there was any other way to stop them popping off? Cheers Davey Quote Link to comment Share on other sites More sharing options...
Lee_e Posted November 7, 2010 Share Posted November 7, 2010 happened to me a few times aswell... got very annoyed and took it to my local garage and they just put new clips on and all is well now might be worth investing in some new clips/tighteners and go from there, they also suggested about beeding the lip for more grip on the pipes etc but to be honest it was tooo much hassle. Quote Link to comment Share on other sites More sharing options...
Davey001 Posted November 7, 2010 Author Share Posted November 7, 2010 I'm getting really annoyed!! Every time I take it out its popping off once it gets warm. I have stainless T- Clamps on but the last thing I want to do now is start stripping all the pipe work back off to get them beaded!! Thanks for the advice! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 7, 2010 Share Posted November 7, 2010 Are T clamps like Mikalors? That should sort it but the only way really is to put some weld round like you said Quote Link to comment Share on other sites More sharing options...
Davey001 Posted November 7, 2010 Author Share Posted November 7, 2010 Yeah I have similar to Mikalors, think that is just the brand. Quote Link to comment Share on other sites More sharing options...
Kirk Posted November 7, 2010 Share Posted November 7, 2010 (edited) Murray constant tension clamps are what you want, not cheap, not 'BLING' but good enough for WRC cars. http://www.owendevelopments.co.uk/products/product-detail.asp?prodId=197&catId=26&subId=-1 EDIT: Are your IC pipes beaded at the ends? Edited November 7, 2010 by Kirk (see edit history) Quote Link to comment Share on other sites More sharing options...
JamieP Posted November 7, 2010 Share Posted November 7, 2010 Mikalors are total sh1t, clean everything with brake/carb cleaner and use proper jublie clips or the murray ones mentioned above, mine holds 2+bar like that. Quote Link to comment Share on other sites More sharing options...
Davey001 Posted November 7, 2010 Author Share Posted November 7, 2010 Sounds good! Will give it a try! Thanks everyone for your help! Quote Link to comment Share on other sites More sharing options...
Davey001 Posted November 7, 2010 Author Share Posted November 7, 2010 No my pipes are not beaded. Quote Link to comment Share on other sites More sharing options...
SimonB Posted November 7, 2010 Share Posted November 7, 2010 Nothing will hold without a bead or something on the pipes. If you have aluminium pipes then you would have to do the clamp up so tight it would bend the pipe to get it to hold otherwise. The bead doesn't need to go all the way round. You can do a temporary job by drilling several holes at the end of the pipe and using rivets - the bit of rivet that sticks out acts as a bead. Quote Link to comment Share on other sites More sharing options...
Kirk Posted November 7, 2010 Share Posted November 7, 2010 Or just get them done with a beading tool Quote Link to comment Share on other sites More sharing options...
hodge Posted November 7, 2010 Share Posted November 7, 2010 I've always found mikalors to be great. They tighten very well indeed with no issues. Quote Link to comment Share on other sites More sharing options...
Davey001 Posted November 7, 2010 Author Share Posted November 7, 2010 Whats a beading tool? Rivet idea sounds a good way around it!! Its the same pipe that blows every time. I could try it with that pipe first. Quote Link to comment Share on other sites More sharing options...
Kirk Posted November 7, 2010 Share Posted November 7, 2010 Its basicly a rolling tool which you clamp the pipe to and it creates a bead in the pipe as you roll it. Xz1ic-w_gsU&feature=player_embedded Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 7, 2010 Share Posted November 7, 2010 i just put a chissel inside the pipe and dent a small pice out on 4 oposite sides , yeehaaaa Quote Link to comment Share on other sites More sharing options...
Lude Posted November 8, 2010 Share Posted November 8, 2010 jubilee clips done up very tight Quote Link to comment Share on other sites More sharing options...
