James Posted November 7, 2010 Share Posted November 7, 2010 Was changing over my front crossmember and had the FMIC, radiator, air con rad, airbox, lights etc. all out of the way and found this clip/sensor. Now, I already removed the higher up of the two horns to be able to fit a rad cooling plate. The wire from it goes to a little loom section that splits to the other horn which you can see below. Now, being really thick most likely, that is just for the other horn right? Got a bit confused as I couldn't remember! All it says on it is Denso 077500-4031. The only other things I thought of was something to do with the air con or an air temp sensor maybe? I don't know! Just checking! Thanks! Quote Link to comment Share on other sites More sharing options...
nevins Posted November 7, 2010 Share Posted November 7, 2010 Ambiant air temp sensor by the looks of it fella. Quote Link to comment Share on other sites More sharing options...
nevins Posted November 7, 2010 Share Posted November 7, 2010 100% sure it it is fact lol Quote Link to comment Share on other sites More sharing options...
L18msy Posted November 7, 2010 Share Posted November 7, 2010 Yup! Quote Link to comment Share on other sites More sharing options...
James Posted November 7, 2010 Author Share Posted November 7, 2010 Ok awesome! That's fine! Now to find where I put that other horn then Quote Link to comment Share on other sites More sharing options...
James Posted November 7, 2010 Author Share Posted November 7, 2010 Duh that's right, it's for the air con. What a thicket! Quote Link to comment Share on other sites More sharing options...
Hamilton Posted March 11, 2024 Share Posted March 11, 2024 Resurrecting an old thread- does anyone happen to know where this air temperature sensor should clip into, or better yet have a photo? I currently have the front bumper off and noticed it’s just hanging there, but presumably it should secure to something… Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted March 11, 2024 Share Posted March 11, 2024 (edited) I think it clips into the front aluminium bumper bar. https://www.mkivsupra.net/topic/161006-fitting-clock-with-outside-temp/?do=findComment&comment=2260580 Edited March 11, 2024 by mwilkinson (see edit history) Quote Link to comment Share on other sites More sharing options...
Hamilton Posted March 12, 2024 Share Posted March 12, 2024 On 3/11/2024 at 5:40 PM, mwilkinson said: I think it clips into the front aluminium bumper bar. https://www.mkivsupra.net/topic/161006-fitting-clock-with-outside-temp/?do=findComment&comment=2260580 That’s a useful link, thank you. I hadn’t realised it clipped to the bumper- I have an aftermarket bumper which is presumably why the sensor was left hanging. I’ll try to find a home for it! Quote Link to comment Share on other sites More sharing options...
