cams for an N/A non VVTI
sim1987
Hi all just been browsing the mvp motorsport web page and found somthing that is disturbing me as i have been looking for a set of intake and exhaust cams and then i read this
Quote:
you can not put an aftermarket exhaust camshaft in any year Non-Turbo, only an intake cam.:shock:
i just want to confirm this if this is true or not
Piper or Kent Cams will do one offs, or maybe they will re grind the existing profile, but you'd end up with a smaller base circle diameter, meaning you'd need different cam followers made. Depending how much smaller the base circle ends up you MIGHT get away with thicker shims. None of this will be cheap.
