Guest nbruch1939 Posted June 14, 2005 Share Posted June 14, 2005 This is the problem I have a 1994 TT Supra, When I floor it the first turbo spools up fine at the point where the Second turbo should kick in I loose all boost. Gauge reads 0 psi until I release throttle, I floor it again and it does the same thing . However, the strange thing is it doesn't do this all the time sometimes both turbos work fine. I read somewhere to put my car into ttc mode. I did that and turbos worked fine, but then I couldn't fine the link that stated what possible problems this eliminates. My car is a BPU running 17 PSI (when working right) Quote Link to comment Share on other sites More sharing options...
Scoboblio Posted June 14, 2005 Share Posted June 14, 2005 Hi mate, take a look at this thread; http://www.mkivsupra.net/vbb/showthread.php?t=35926 Sounds like you have problem no.2 Quote Link to comment Share on other sites More sharing options...
Guest nbruch1939 Posted June 15, 2005 Share Posted June 15, 2005 I've checked all the hoses they were all OK Now What By the way thanks for the help. Quote Link to comment Share on other sites More sharing options...
toyo rob Posted June 15, 2005 Share Posted June 15, 2005 check the pipe leading to the pressure tank, behind the injection side of the engine, 2 small pipes, they caused me a load of problems with mine leaking boost all over the place. if ur still standard seq then find Ian C and go to his website, loads of pic of whatand where the pipes are and lead. good luck Rob Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 15, 2005 Share Posted June 15, 2005 me too. Of course it's always the hardest one to get to as well ! Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted June 15, 2005 Share Posted June 15, 2005 got a pic of these two pipes?? Quote Link to comment Share on other sites More sharing options...
Guest nbruch1939 Posted June 16, 2005 Share Posted June 16, 2005 Ok I checked all hoses and tubes, also I checked the actuators to make sure they were opening at the correct PSI. Plus I checked the pressure tank, everything checked out. Were do I go from here? Quote Link to comment Share on other sites More sharing options...
jayssupra Posted June 16, 2005 Share Posted June 16, 2005 my car is doing that as well,but my boost only dropped to 0.3-0.4 bar when second turbo came in, could not find anything wrong with pipes so booked car into toyota, car has been in for 7 days now and still nothing, i'll let you no what the problem is when i find out. Quote Link to comment Share on other sites More sharing options...
Guest nbruch1939 Posted June 16, 2005 Share Posted June 16, 2005 Please do let me know when you find out something, I've drove myself nuts tryiny to figure it out. "Obi-wan your my only hope" Quote Link to comment Share on other sites More sharing options...
Guest slow dog Posted June 16, 2005 Share Posted June 16, 2005 ring me 07788528477 Quote Link to comment Share on other sites More sharing options...
