JamieP Posted November 4, 2010 Share Posted November 4, 2010 Having trouble finding these, can any traders get them for me or anyone find some online? need aluminium, Jamie:) Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 4, 2010 Share Posted November 4, 2010 You will probably have to source those from the USA, and even then maybe buy a none weld on fitting and turn off what you don't need. -24 is enormous, well beyond what race cars use, but some aircraft will use cooler lines that big. I would guess even the cheapest male / male or weld on with be 60 quid each or more. God knows how much -24 hose is Link to comment Share on other sites More sharing options...
JamieP Posted November 4, 2010 Author Share Posted November 4, 2010 Hi Chris, Its to replace my top rad hose, the rad and water neck measure 35mm id and so does -24, i have the hose and fittings i need, just need the weld ons, i have a -24 male to male i could cut in half and use i guess but would rather the proper fitting. Link to comment Share on other sites More sharing options...
RobUK Posted November 4, 2010 Share Posted November 4, 2010 Hi JP Have you tried asking a local Hydralics company? I went to a local one (Oxford- http://www.mfhydraulics.co.uk) and got them to make a fuel line to go from the fuel filter to the rail.... they did it while I waited. These type of company tend to do big stuff like tractors, lorry's etc.... Hope it Helps Rob Link to comment Share on other sites More sharing options...
JamieP Posted November 4, 2010 Author Share Posted November 4, 2010 Local places i tried only seem to have steel weld on fittings. Link to comment Share on other sites More sharing options...
RobUK Posted November 4, 2010 Share Posted November 4, 2010 Maybe try the above.... if you need someone local to facilitate anything then let me know and I can pop down to them for you Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 4, 2010 Share Posted November 4, 2010 -20 is about the biggest size you will fairly easily find in alloy. If you have -24 male / male I'd turn it off into two parts and TIG them / it on. -24 in alloy is NOT going to be easy to find. I have checked out three US aerospace companies I deal with and they show nothing that big. You really do like spending money, don't you? -24 indeed A good turner could lathe cut threads and the taper that size, if you wanted something bespoke. Link to comment Share on other sites More sharing options...
JamieP Posted November 4, 2010 Author Share Posted November 4, 2010 I will give them a try tomorrow Rob, thanks for the offer mate. Link to comment Share on other sites More sharing options...
JamieP Posted November 4, 2010 Author Share Posted November 4, 2010 -20 is about the biggest size you will fairly easily find in alloy. If you have -24 male / male I'd turn it off into two parts and TIG them / it on. -24 in alloy is NOT going to be easy to find. I have checked out three US aerospace companies I deal with and they show nothing that big. You really do like spending money, don't you? -24 indeed A good turner could lathe cut threads and the taper that size, if you wanted something bespoke. Thanks Chris, might have to do that. Link to comment Share on other sites More sharing options...
heckler Posted November 4, 2010 Share Posted November 4, 2010 well, I know stuff bigger than -24 is out there because some of the fittings used on chinooks is massive, not sure what the size is but the pipes alone are 2" and bigger in diameter and they all have JIC fittings Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 4, 2010 Share Posted November 4, 2010 I have never seen anything beyond -32, and that's huge! We need a good war then the survivors can raid the war surplus stores that spring up Link to comment Share on other sites More sharing options...
heckler Posted November 4, 2010 Share Posted November 4, 2010 might have a poke around a chinook tomorrow and see how big they are... Link to comment Share on other sites More sharing options...
baldy Posted November 5, 2010 Share Posted November 5, 2010 jamie my local fitting company say they can get them,their supplier has 2 in stock Link to comment Share on other sites More sharing options...
dandan Posted November 5, 2010 Share Posted November 5, 2010 What's all the fuss about - $20 each Part number 997124 in aluminium. http://www.anplumbing.com Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 5, 2010 Share Posted November 5, 2010 Good find Dan, and prices are very reasonable. Link to comment Share on other sites More sharing options...
JamieP Posted November 5, 2010 Author Share Posted November 5, 2010 jamie my local fitting company say they can get them,their supplier has 2 in stock Hey Si, have you got a number for them? Link to comment Share on other sites More sharing options...
baldy Posted November 5, 2010 Share Posted November 5, 2010 its pirtec crawley opposite my shop 01293 571707,not cheap from them though Link to comment Share on other sites More sharing options...
